Water Flow Sensor + Relay Shield Arduino
Hello you guyz
How can I do a code that read the water flow and blocking the water with a selenoid valve and relay shield?
I have a water flow sensor connected with a selenoid valve. When the sensor reads ~hypothetically~ 1L of water the relay cut off the connection with selenoid valve, blocking the water flow.
Can everyone help me?
*I know the hardware connections, i just need a code.
Thanks :slight_smile:
Sure:
if (waterFlown > 1) digitalWrite(relayPin, LOW);
where waterFlown is a float containing the amount of water measured in litres; relayPin connects to your relay (active HIGH).
