If you're leaking for leaks, presumably the way to detect that is that the flow rate never quite drops to zero. So, rather than looking for a sustained high flow, you would need to look for a sustained period with a constant, low but non-zero flow. With that many outlets, there may only be a few times of the day when you can confidently predict that the flow should really be zero.
