Water level and relay code!
I finished my code and everything work great
but i have problem with my relay,
digitalWrite(Relay, HIGH);  // turn on relay
   if (95)-(distance) < (35);
   digitalWrite(Relay, LOW);   // turn off relay
   if (95)-(distance) = (70);
as you can see i want the relay ON when (95)-(distance) < (35)
& OFF when (95)-(distance) = (70)
I have this error
water.ino: In function ‘void loop()’:
water:78: error: lvalue required as left operand of assignment
and this is my full code
#include <LiquidCrystal.h>
#define ECHOPIN 3                            // Pin to receive echo pulse
#define TRIGPIN 4                            // Pin to send trigger pulse
#define STATUSPIN 13                        // Use for troubleshooting
int Relay = 6;
int highWater = 30;        // These values allow to calculate % of full
int lowWater = 100;        // SRF04 hangs above water (lower distance = more water)
byte symbol[8] = {         // Custom character for LCD display
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
byte eq[8] = {
        B00000,
        B00000,
        B01001,
        B10110,
        B00000,
        B01001,
        B10110,
        B00000
byte h[8] = {
        B00100,
        B01110,
        B10101,
        B00100,
        B00100,
        B10101,
        B01110,
        B00100
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);    // Assign pins
// Utility function for flashing STATUSPIN
void flashLed(int pin, int times, int wait) {
  for (int i = 0; i < times; i++) {
    digitalWrite(pin, HIGH);
    delay(wait);
    digitalWrite(pin, LOW);
    if (i + 1 < times) {
      delay(wait);
  lcd.begin(16,2);
  lcd.print("   AQUA LEVEL ");
  lcd.createChar(0, symbol);
  lcd.createChar(1, eq);
  lcd.createChar(2, h);
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  pinMode(Relay, OUTPUT);
  delay(3000);       // Show application name for 3 seconds.
  // Measure distance
  digitalWrite(TRIGPIN, LOW);                   // Set the trigger pin to low for 2uS
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);                  // Send a 10uS high to trigger ranging
  delayMicroseconds(10);
  digitalWrite(TRIGPIN, LOW);                   // Send pin low again
  int distance = pulseIn(ECHOPIN, HIGH);        // Read in times pulse
  distance= distance/58;                        // divide by 58 gives cm.
  // Convert measured value to value between 0-16, to display on LCD
  // Use Arduino built-in map and constrain functions
  int scaledValue = map(constrain(distance, highWater, lowWater), lowWater, highWater, 0, 16);
  lcd.clear();
  lcd.setCursor(0,0);
  while (scaledValue > 0) {
     lcd.print((char)0);
      scaledValue--;
lcd.setCursor(0, 15);
lcd.print("%");
// CM
int cm;
cm = (95)-(distance);
lcd.setCursor(0, 1);
lcd.print(( char)2);
lcd.print(cm);
lcd.print(" CM   ");
// litres
int litres;
litres = 20 * (95 - distance);
lcd.print(( char)1);
lcd.print(litres);
lcd.print(" L");
//send pulse every 3 second
   delay(9000);
Do you mean
if ((95 - distance) == 70)
A comparison requires ==.
And remove the ;
// Convert measured …
Is this supposed to happen if above true?
If so remove the ; and use {} around the code to be done and add ()
if (95-distance) == 70)
You do not need brackets around each value.
Weedpharma
Edited when noted more problems!
…and the if command should continue because the “;” ends it.
   if((95-distance) < 35) // ; <- this
:roll_eyes: nothing work for now i try everything
Well, let's see the changes you made, then.
Post your new code and give a full description of what is happening.
Weedpharma
You’re still doing it:
 else if (95)-(distance) <=70) {
sorry wait i upload the wrong code :confused:
UPDATE
now it’s work
int Relay = 6;
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
byte eq[8] = {
        B00000,
        B00000,
        B01001,
        B10110,
        B00000,
        B01001,
        B10110,
        B00000
byte h[8] = {
        B00100,
        B01110,
        B10101,
        B00100,
        B00100,
        B10101,
        B01110,
        B00100
    delay(wait);
      delay(wait);
  lcd.begin(16,2);
  // Measure distance
 if (95-distance <= 35) {
   digitalWrite (6,HIGH);
 else if (95-distance >= 70) {
   digitalWrite (6,LOW);
  lcd.clear();
  lcd.setCursor(0,0);
     lcd.print((char)0);
      scaledValue--;
lcd.print("%");
// CM
int cm;
lcd.print(cm);
lcd.print(" CM   ");
// litres
int litres;
lcd.print(litres);
lcd.print(" L");
   delay(9000);
thanks everyone :wink:
Don't edit your old post!
all the problem was from “IF” i used in the second line “else if” and it’s work now.
+1 for everyone here, thanks :slight_smile:
