Water Level control via Analog Input
Hello,
I am trying to make an automation controller with Arduino to fill and discharge a water storage tank. I am new to programming and need some guidance. I plan on using a submersible level sensor as my AI and control a relay board module to open a solenoid valve to fill and close when sensor senses tank is full.
Then, using a pressure transducer to control a signal to a VSD to power a water pump to discharge from water storage tank. Just a basic Start/Stop signal to call for VSD to run between a pressure threshold.
Can this be done with Arduino? I am not sure out to start or how to begin the programming, if its even possible. Any help is appreciated. TIA.
Posting a link to the sensor datasheet would be good.
The level sensor is a 2-wire 24VDC, 4-20ma and the pressure transducer is a 3-wire, 0.5-4.5V. I plan to use a current to voltage converter module for the level sensor.
Thank you. I will def look into that.
I wasn't sure if I would be able to perform both functions at the same time.
You may need a second solenoid valve to stop siphoning of the tank water when the pump is turned off. Do you have any safety controls when the tank filling doesn't work and the pump runs out of water?
Good. Which controller are You using? 5volt logic or 3.3 volt logic? (Vcc)
Feed the current through a resistor that has the value of 3.3/0.020 = 165 Ohm, or 5.0 / 0.020 = 250 Ohm. Connect the sensor signal line to an analog input and the resistor other end to GND.
So, I've been digging deep into this and haven't done any conversions for sensors, yet.
But I've been testing the code through a simulator and having issues with the loop.
I suspect it has to do with the delay in the serial printing but then level goes low, alarm appears, and pump digitaloutput goes out.
When put into the simulator, it has a blip and digital output (relay1) turns on then off. I want it to stay off while in "alarm". Any advice how I can fix this or suggestions? Again, still learning. Thanks in advance!
const int lvlSensor = A1;
const int relay1 = 8;
const int presSensor = A2;
const int relay2 = 7;
const int alarm = 13;
//relay and sensor outputs
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(lvlSensor, INPUT);
pinMode(presSensor, INPUT);
pinMode(alarm, OUTPUT);
 //serial printing for analog inputs  readouts
  int lvlSensor = analogRead(A1);
    Serial.println(lvlSensor);
  int presSensor = analogRead(A2);
    Serial.println(presSensor);
    delay(2000);
//if Tank Level is below 25%, then alarm goes off and Pump is Off until alarm clears
  if(analogRead(A1) <255) {
    digitalWrite(13, HIGH);
    digitalWrite(8, LOW);
   } else if (analogRead(A1) >255){
      digitalWrite(13, LOW);
Then include the "alarm" status as part of the condition to control the relay.
How do I go about doing that? I'm not familiar with all the functions. Could you point me in the right direction to do some further research? Thank you for the suggestion.
You want it to stay off in "alarm". What is alarm and where is it set and where is it reset? What is "alarm" in your code? Include the "alarm" status before deciding to turn on the pump. Likely there are NO FUNCTIONS involved!
I will try to explain what I'm trying to do. If it would help, I can send the whole code of what I have so far.
I'm taking an analog Input (A1), reading and printing the information. When A1 gets below 25% value, it goes into alarm (turns on a buzzer on a DO) and also turning off A1 at the same time. When it reaches above 25%, Alarm is off and pump is back on.
What I have so far works, somewhat. My question is... when I put it into a simulator to run and test the code, the output for Pump (A1) turns on every, I'm assuming every 2500ms, due to the delay in the serial printing readout. Adjusting the delay doesn't work. And I've been trying to code BWD for the serial printing but failing to make it work properly.
I want it to stay off, completely, until the value reaches above 25%. I'm just trying to wrap my head around where I'm going wrong with it and If there's a better way to command the alarm.
    delay(2500);
   ///if tank level is below 100% (pump on), if level is greater than 25% (pump off)
  if (analogRead(A1) < 1023) {
    digitalWrite(8, HIGH);
  } else if (analogRead(A1) > 154){
  ///if Tank Level is below 25%, then alarm goes off and Relay1 off
Then you need to remember that the alarm is in effect. How would you do that in your code?
Which Arduino?
What is the output voltage when the input current is 4mA? When 20mA?
Definitely not in a simulator and maybe yes or no with actual hardware
But that first condition on A1 seems to give a HIGH for any value between zero and 1022?
