hello frnds/sir,
i need make a project for my home use motor. i try to make code every time is come with error,i am a begginer.pls help me.here i send you structure
two display 1 lcd ,6- 7 segment and sonar hc 04
standby mode lcd and 7 seg- first line indicate water level in tank then volume then same reservoir(this line scrolling delay then scorolling delay)
7 seg (3 seg for each)thats indicate onlt % of volume of 2 tank
and second line of lcd indicate rtc(ds1307) time day and date in short form and indicate motor status automatic or manual(also that scrolling)
and time display pannel in another 6 -7 segment 12(hrs)
and lcd light on when light sensor led 7 seg always on
operation
4 input buttons two output for buzzer and relay(5v)
1- system on/select
2-up/down
3-manual motor on /off
hello frnds/sir,
when motor on 2nd line indicate that and buzzer on
operation
1- system on/select
2-up/down
system on-main display
automation
automatic
manual
set
volume set
tank 5%(increse by 5)
rsv 1 ft (increse by 1ft)
on/0ff
time set
hors/min
on/ off
timer
1, 2,3,4,5,6,7,8,10,11,12 min
on/off
back
and missing part from me pls add
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
thanks for try to helping me .. i am beginner for arduino and lot of coding problem in my head. first apologize for above two posting that happened due to lost of my internet connection.
the second post(motor control) is project in my head. i got 2 uno board and pro mini board,max 8 digit 7 segment and ds rtc module and etc..still not create circuit.
In my project
first i want to write code to text scrolling with sensor value(tank level) in first line and time second line
