Water level indicator and pump controller project proposal
I am a beginner for Arduino, however an Idea to make a domestic Water Tank level indicator and Pump controller project proposal, if i give all details and my requirement, who will be able to complete my project perfectly?
thank you all,
That would be you, unless you decide to have a moderator move this thread to the Jobs and Paid Consultancy section and pay someone. This is not a free design and coding service.
If you want help to do the project, post the details and we can assist you.
You have to use arduino and water level sensor like this:Water Level Sensor Depth of Detection Water Sensor for Arduino
For the indication part, you may get some idea from here: Water Level Indicator using Arduino - The Engineering Projects
To switch on/off your water pump automatically, you have to choose a relay board according to your motor's current rating.
have a look at liquid-level-sensing-using-a-laser-tof-sensor
I recently tested VL53L1x as a water level sensor - worked OK
The lowest bidder.
Your project is the sort of thing Arduino boards were made for.
But you are going to have to do some groundwork of your own so that you can clearly state what you want to do.
You could what you want to do with some float switches, lamps and relays without an Arduino in sight.
Would that work for you?
Your answer will be an insight into what you want to achieve.
The lowest bidder may well be able to complete the project. But perfectly? That's a whole different bag of cats :wink:
Think about how you will supply the developer with equipment to test his/her program as it is being developed.
Can of worms where I come from.
Rats in a barrel?
Faster than a rat up a drainpipe.
They need to be fast if I find them in the compost bin.
that depends on how much $$ you're willing to offer
