Water Level Sensor
can i use PT-500 Submersible Pressure Transducer with Arduino microcontroller board to measure water level in tank or borewell.
description of sensor.
how to connect to Arduino?????
plz help its urgent.
tim3in:
  1. Yes
  2. With wires.
I suppose you are going to use the 4-20mA current output version.
Enter "4-20" in the search box on top of this page.
A 12volt supply and a resistor are needed.
The 12volt supply could also supply the Arduino.
Leo..
Do not double post.
Yes, but very $$$ solution.
$848.00
http://www.fondriest.com/apg-pt-500-submersible-pressure-transducer.htm
sonnyyu:
$848.00
I too am interested in water level sensors.
or $362
https://www.telematic.com/product/5630/pt-500-series-level-transmitter
got any suggestions on alternatives that are lower cost ?
can go 450 feet deep
that can handle sludge ?
dave-in-nj:
...can go 450 feet deep that can handle sludge ?
I'm sure that's where the high cost comes in...
sonnyyu:
$848.00
in a septic system that costs about $10,000 a day to run, or maybe $10,000 an hour when out of commission. a $2,000 sensor that lasts for years is a cheap, DIRT CHEAP, solution.
a sensor that was guaranteed to last 5 years without maintenance could comman $25,000.
and it would be used, probably with a second as a redundant sensor.
aarg:
+1
Cable is waterproofing cable, say IP69 cable could easily cost more than $1/meter at OEM. plus it is not customer modifiable, need order sensor with correct cable length.
IP Code:International Protection Marking.
