Good evening, can someone give me a code that lets you run a 3v water pump when the lm35 reaches the desired temperature? thank you
if (readLM35 () >= threshold)
run3VwaterPump ();
Not likely. You write the code and we help to get it working. If you really want someone to write the code for you, post in the Gigs and Collabarations section. Be prepared to pay and provide a detailed program specification and specifications of the hardware.
I have the following code, the temperature is always changing between negative and positive values which causes a pump to always turn on and off, I may have a code error, can someone help me?
float temperatura = 0.0;
int waterpump = 8;
void setup(){
Serial.begin (9600);
pinMode(8,OUTPUT);
void loop(){
temperatura = (0.5 * analogRead(0)*5/(1023))/0.01;
Serial.println (temperatura);
delay (2000);
if (temperatura < 14){
digitalWrite(8, LOW);
}else
digitalWrite(8,HIGH);
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom...
You may have a type casting issue in your equation.
try
temperatura = (0.5 * (float)analogRead(0)*5.0/1024.0)/0.01;
Then comes the question, why multiply by 0.5 and divide by 0.01? x0.5/0.01 is the same as x50.0.
Please try to analogRead twice and optimize your math, like this:
analogRead(0); //Discard this reading
temperatura = (float)analogRead(0) * 0.244f; //Optimized math
Why are we reading twice when reading the same input?
adwsystems:
Something to do with initialization of ADC.
Initialization as in the first time. Your suggestion does it everytime.
If that's an issue, then add an analogRead to setup().
I do agree it is useful when reading multiple analog input channels.
What kind of temperature sensor are you using?
Looks like you need some hysteresis (dead band), try:
if (temperatura < 14.0)
else if(temperatura > 15.0)
Should be;
temperatura = (0.5 * analogRead(A0)*5/(1023))/0.01;
At the moment you are trying to read one of the program comms pins.
You need to look at analog input A0.
Tom..
temperatura = (0.5 * analogRead(0)*5/(1023))/0.01; Post#3
temperatura = (0.5 * analogRead(0)*5/(1023))/0.01; Post#5
try
temperatura = (float)analogRead(0) * 0.244f; Post#6
temperatura = (0.5 * analogRead(A0)*5/(1023))/0.01; Post#11
1. The response equation of LM35: T0C = 100*SignalOutFromSensor
Assuming VREF = 5V (DEFAULT)
SignalOutFromSensor = (5/1024)*analogRead(A0) or (5/1023)analogRead(A0)
==> T0C = 100(5/1024)analogRead(A0);
float T = 100(5.0/1024)*analogRead(A0); //tested; OK! shows: 25.37 C
//------ from Post#3---------------------------------------
float temperatura = (0.5 * analogRead(0)*5/(1023))/0.01; //tested: not OK! shows: 14.91 C
//----- from Post#5-----------------------------------------
temperatura = (0.5 * (float)analogRead(0)*5.0/1024.0)/0.01; //tested: not OK! shows: 14.14 C
//-----from Post#6-------------------------------------------
temperatura = (float)analogRead(0) * 0.244f; //tested: not OK! shows: 14.13 C
//----- from Post#11------------------------------------------
temperatura = (0.5 * analogRead(A0)*5/(1023))/0.01; //tested: not OK! shows: 14.66 C
The equations are failing; because, they are not logically formed.
For input signal 5V (when VREF = DEFAULT), the ADC value is 1023 (or 1024)
For input signal VDT (SignalOutFromSensor), the ADC value is (1023/5)*SignalOutFromSensor
Therefore: ADC = (1023/5)*SignalOutFromsensor
==> SignlaOutFromSensor = (5/1023)*ADC = (5/1023)*analogRead(adc_Channel#)
Therefore, the response equation of LM35 becomes as:
T0C = 100SignalOutFromSensor
==> T0C = 100(5/1023)*analogRead(A0); //A0 is the Arduino name for ADC_Channel_0
We want to present the temperature as integer, the declaration is:
unsigned int T = 100*(5/1023)*analogRead(A0); //no fractional part will be shown
We want to present th etemperature as flloat, the declrarion is:
float T = (float)100*(5/1023)*analogRead(A0); //this is preferred to the next one.
OR
float T = 100*(5.0/1023)*analogRead(A0); //it is enough to have one factor is float. But, which one?
2. Interestingly, if we change the order of factors of the temperature equation of this Post, the response goes crazy! (I saw a post in the Forum having a change in the order of the placement of the factors.)
float T = 100*(5.0/1024)*analogRead(A0); //tested; OK! shows: 25.45 C
==> float T = 100*(analogRead(A0)/1024)*5.0; //tested: not OK! shows: 0.00
analogReference(DEFAULT);
//float T = 100*(5.0/1024)*analogRead(A0);
//Serial.pruntln(T, 2);
// float temperatura = (0.5 * analogRead(0)*5/(1023))/0.01;
//float temperatura = (0.5 * (float)analogRead(0)*5.0/1024.0)/0.01;
//float temperatura = (float)analogRead(0) * 0.244f;
//float temperatura = (0.5 * analogRead(A0)*5/(1023))/0.01;
//Serial.println(temperatura, 2);
Serial.println(T, 2);
delay(2000);
TomGeorge:
Hi,temperatura = (0.5 * analogRead(0)*5/(1023))/0.01;
Should be;
Tom..
Tom - actually not.
On a UNO this is how A0 is defined
static const uint8_t A0 = 14;
or on a MEGAstatic const uint8_t A0 = 54;
if you look at the source code for analogRead you'll see that they do some math to bring back the pin number between 0 and n-1 (whatever the number of analog pins you have) and this is also documented as such:
Syntax
analogRead(pin)Parameters
pin: the number of the analog input pin to read from (0 to 5 on most boards, 0 to 7 on the Mini and Nano, 0 to 15 on the Mega)
This is the only function that works from a channel though, if you use the wrongly named analogWrite()
(as it is used for PWM) then you need to pass the appropriate pin number and 0 will not be A0 in that case.
Agree though it's confusing and best practice is to use A0 IMHO
GolamMostafa:
float T = 100(5.0/1024)*analogRead(A0); //tested; OK! shows: 25.37 C//------ from Post#3---------------------------------------
float temperatura = (0.5 * analogRead(0)*5/(1023))/0.01; //tested: not OK! shows: 14.91 C//----- from Post#5-----------------------------------------
temperatura = (0.5 * (float)analogRead(0)*5.0/1024.0)/0.01; //tested: not OK! shows: 14.14 C//-----from Post#6-------------------------------------------
temperatura = (float)analogRead(0) * 0.244f; //tested: not OK! shows: 14.13 C//----- from Post#11------------------------------------------
temperatura = (0.5 * analogRead(A0)*5/(1023))/0.01; //tested: not OK! shows: 14.66 Cfloat T = 100*(5.0/1024)*analogRead(A0); //tested; OK! shows: 25.45 C
Please try your explanation again. And I will give you a hint, it has nothing to do with any of this:
GolamMostafa:
For input signal VDT (SignalOutFromSensor), the ADC value is (1023/5)*SignalOutFromSensorTherefore: ADC = (1023/5)*SignalOutFromsensor
==> SignlaOutFromSensor = (5/1023)*ADC = (5/1023)*analogRead(adc_Channel#)Therefore, the response equation of LM35 becomes as:
==> T0C = 100(5/1023)*analogRead(A0); //A0 is the Arduino name for ADC_Channel_0We want to present the temperature as integer, the declaration is:
unsigned int T = 100*(5/1023)*analogRead(A0); //no fractional part will be shownWe want to present th etemperature as flloat, the declrarion is:
float T = (float)100*(5/1023)*analogRead(A0); //this is preferred to the next one.OR
Notice that you have to results listed as OK that are almost 0.1 degrees apart, but yet the two results that are 0.01 degrees apart are not OK. ? ? ?
Post #3 and post#11 are absolutely the same thing. So as to how you got different results is beyond reasoning. The only change is the pin number used in the IDE, but the compiler resolves both back to the same ADC configuration and input.
Post #5 and Post #6 are likely only different due to a truncation issue. Post #6 lists the fact as 0.244 but if you calculate the factors from post #5 it actually computes to be 0.244140625. If you use the whole thing then post #5 and #6 have the same result. The only same result throughout the entire list. Hmmm?
Try to use internal vRef:
#define LM35PIN A0
pinMode(LM35PIN, INPUT);
analogReference(INTERNAL);
float reading = 0;
for (byte i = 0; i < 5; i++) reading += analogRead(LM35PIN);
//Calculate reading average: reading *= 0.2f;
//Convert reading to celcius: reading = reading / 1024.0f * 4640.0f / 10.0f;
//Both above shortened to:
reading = reading * 0.2f / 9.31f;
Serial.println(reading);
This works with LM35DZ and Uno and yields higher resolution than default vRef.
Why do you bother to set the pinMode of an analogue input?
Don't you trust analogRead?
TolpuddleSartre:
It makes reading the code easier.
[soapbox]
In my opinion not declaring all inputs and outputs in setup that are possible, is lazy.
Declaring ALL I/O means you have in one list ALL the pins you are using.
For someone who is trying to debug someone else's code, it is invaluable.
It does not gobble up valuable controller memory.
[\soapbox]
Tom..
