water pump power
I have a water pump coming from spark fun Liquid Pump - 350GPH (12v) - ROB-10455 - SparkFun Electronics it is 350 GPH
I am planning on attaching this to a large plastic container (tub) to make a robotic boat. I wondering if
there is any way to figure out how much weight I can put on the boat before the pump does not have
enough power to move it.
arduinopi:
You're going to want to take a look at http://www.homebuiltrovs.com/. They have done some testing in this area using this test stand: http://www.homebuiltrovs.com/teststand.html. We used a similar pump, but converted it to use a 30mm propeller. It moved our ~90lb ROV at roughly 1.5mph.
