Water Sensor and LED
Hello, I am a beginner in C++ and am trying out something, what I want the program to do is light up an LED when it is between a certain water level, but the LED is not lighting up no matter what.
here is the code
int adc_id = 0;
int HistoryValue = 0;
char printBuffer[128];
pinMode(2, OUTPUT);
    int value = analogRead(adc_id); // get adc value
    if(((HistoryValue>=value) && ((HistoryValue - value) > 10)) || ((HistoryValue<value) && ((value - HistoryValue) > 10)))
      sprintf(printBuffer,"ADC%d level is %d\n",adc_id, value);
      Serial.print(printBuffer);
      HistoryValue = value;
    if (printBuffer <= 200){
      digitalWrite(2,HIGH);
      else(digitalWrite(2,LOW));
Can you try this first and see what values you are actually getting?
   int value;
   value  = analogRead(A0);      // get adc value. (Guessing at pin# here. 0 just seemed wrong.)
   Serial.print(value);
-jim lee
You are comparing the memory address where printBuffer is stored to 200, which is completely unrelated to the value read from the analog port.
How would I go about attaching/ Linking them?
thank you for the feedback.
Instead of:
Did you mean?
 if (value <= 200){
Replace:
with this:
   if (value <= 200)
       digitalWrite(2,LOW);
See what happens.
Thank You, it worked and i also see what I did wrong, silly mistake. Thank you very much
