Hi guys can you help me please I need to use a water sensor as a digital read if there was water so it's high and vice-versa
@ahmedyacine123
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Is this project for a short term test or long term operation.
Option:
- simple conduction
- floating magnet
- ultrasonic measurement
- capacitance sensor
- micro switch float mechanism
- optical float sensor
Use either:
if (digitalRead(sensor_pin) == HIGH) do_something();`
or
if (digitalRead(sensor_pin) == LOW) do_something();
tanks I will try it
You will get better advice if you read and follow the suggestions in the forum guidelines.
@ahmedyacine123
After hijacking one topic you now have started another on the same subject. Please read the forum rules, which have now been pointed out to you twice, before posting again. If you continue to ignore the rules you will get a break from the forum.
Thank you.
I'm hurt
Forgive my poorly worded post. Perhaps more detailed advice?
More advice, certainly!
How drôle!
The point is, to pose a question here, you start by explaining yourself; your actual project.
Do you actually have a water sensor? What one is it? The Web link for it if you please?
What is the "tank" in question? Why do you need to monitor it?
What "Arduino" or similar are you using?
Once you start to provide information, we can actually help you.
I created a water tank monitoring system a couple years ago based on this
using a ESP8266 NodeMcu
i added flow meters to the in and out
water in the tank is old geometry
volume of a cylinder, radar tells you where the top of the water in the cylinder is.
then constants, water volume per gallon
