Water TDS Measurement
Hey everyone,
i was wondering if it's possible to make this type of TDS measurement work on a arduino. Here is the link http://hal.inria.fr/docs/00/63/56/52/PDF/TDS_Logger_RJP2011.pdf
He used a pic 18. I've done some experimenting with my arduino , breadboarded a circuit, wrote the code, and tested it with my oscilloscope. I don't think the arduino has the right kind of outputs...watching the oscilloscope the arduino pins seem to drain to ground then set to INPUT. You'd have to read the info in the link above to understand why that's a problem. :slight_smile: Someone PLEASE prove my wrong.... :slight_smile: I'd love this to work...its so simple. I'd use a pic but, I'd have to learn to write code for one first and that seems alot trickier than arduino from want i've seen so far. I haven't been looking very long.
Thanks, Red
Red,
I am not in your field but I have done contract work with water sensing and have the right background to understand your problem. Arduino has the right pins for your application. You may have set the pins or circuits wrong. BTW, fig.1 is missing a resistor. Trying to charge a capacitor without a resistor is going to damage the pins.
Show some pictures of your circuit and post your code. I can try to help you.
It's been awhile since, I did those experiments. I'm getting close the to actually build the project now. posting on the forum was the last try at it with arduino before learning to program and buying hardware for the pic. the circuit was exactly the same as fig 1 but, I had a resister in place for Rx (i didn't have a tds probe to play with). i tried many different values of resistors. Can't find the sketch i wrote back then. I think i may have deleted it after reading somewhere that the pins on the arduino where wrong kind. As far as the code i wrote, it basically went step by step with whats on page 3, in that paper i linked, changing pinModes to match the step and testing on the right pin using a while loop and a counter to see how long that pin was HIGH (i try many different delayMicroseconds in the while loop very small to larger to no delay at all). It also showed a picture on page 4 of what the oscilloscope should look like. testing the circuit with my oscilloscope it looked like very straight up and down spikes on the scope, like when pins switched to an INPUT, the pin grounded and the voltage in the cap dropped very fast without going thru the resister. This seemed to support what i read about the pins being wrong so, i gave up at the time. I'll have to rebuild the experiment again. I'll be able to do a much better job of now, having a lot more practice writing code for the arduino.
thanks, red
Some basic background info:
Inside of a TDS meter is an electrical circuit which measures the resistance between its two electrodes when immersed in a liquid. This circuit applies an AC voltage to the electodes, and then measures the AC current which flows between the two electrodes. This reading is then corrected for temperature (if its a high quality instrument), and electrode geometry. The result is a measure of Total Ionic Content. The name Total Dissolved Solids is actually a misnomer, as a lot of dissolved solids will not read at all on a TDS meter since they do not ionize when they dissolve. Sugar is such a substance. If you were to dissolve a tablespoon of table sugar in a cup of distilled water and read it with a TDS meter, the resulting reading would be zero.
The reason AC is used instead of DC voltage on the electrodes is to keep the metals in the solution from plating onto the electrodes. With AC, anything that plates onto the negative electrode will in theory come off when the polarity reverses. AC also keeps the ions from migrating from one electrode to the other, thereby keeping the solution homogeneous.
Lefty
If the curve you found drops too fast compared with fig. 4, your fake resistor rx is too small. Conductivity of some turbid water is very low. If you use a very large resistor to simulate the water, you will see a gradual drop in voltage instead of straight drops.
redneckengineer:
That behaviour is presumably not what you intended, so there is something wrong with your hardware or software or both. We'd need to see your circuit diagram and software to have any hope of guessing what's wrong.
I rewrote the code. its a little different than whats in the paper. I know its going to have to change to work in my project. as it is this isn’t working on the scope or with serial display. I know its likely a simple problem I’m just missing.
thanks, red
// capacitor based TDS measurement
// pin 10 C+ -750K resistor—|----------|
// 3.3 nF cap 5.6 M to simulate Rx
// | Resistor
// pin 9 C- --750K resistor—| |
// pin 8 EC -----------------------------|
int capPos = 10; //C+
int capNeg = 9; //C_
int EC = 8; //EC
unsigned int timesThruAverage; //times thru “still high while loop”
void setup(){
void loop (){
timesThruAverage = getTdsAverage(); //goto measuring function
Serial.println (timesThruAverage); //display average times thru loop
unsigned int getTdsAverage(){
unsigned int timesThru = 0;
unsigned int setDelay = 0;
unsigned int runningTotal = 0;
for(int i;i<100;i++){ //get a average of 100 times thru still high while loop
//charge cap
pinMode (capPos,OUTPUT);
pinMode (capNeg, OUTPUT);
pinMode (EC, INPUT);
digitalWrite (capPos, HIGH);
digitalWrite (capNeg, LOW);
delayMicroseconds(100);
//let cap drain thru Rx
pinMode (capPos,INPUT); //set C+ to input to keep voltage from grounding a discharging thru this output pin
pinMode (EC, OUTPUT);
digitalWrite (EC, LOW);
//test to see how many times still high loop is HIGH before it goes low
while (capPos == HIGH){ //still high loop
timesThru += 1;
delayMicroseconds (10);
setDelay = timesThru * 10; //set delays down the line so freq has even phases
//fully discharge cap
digitalWrite (capPos, LOW);
delayMicroseconds (setDelay);
//the unmeasured half of ac phase
digitalWrite (EC, HIGH);
delayMicroseconds(setDelay);
runningTotal += timesThru;
timesThru = runningTotal / 100;
return timesThru;
// pin 10 C+ -750K resistor---|----------|
// | Resistor
// pin 9 C- --750K resistor---- |
// pin 8 EC --------------------------------|
hope that circuit is understandable. posting seems to mess it up
The circuit is understandable. You don't need the resistor between pin 10 and capacitor to be so big as 750K something smaller will help charging the capacitor faster yet still restrict the current so it won't damage arduino. Something like 150ohm will be all you need. The other 750Kohm resistor between pin 9 and capacitor is not needed.
hey, i made those changes. it's still is not working. probing with the oscilloscope shows a very ugly and noisily picture. the cap never gets charged to more than 1 volt in either direction. i ve got a rigol 1102e 1 GSa/s scope if that makes any difference. maybe the pins aren't switching between OUTPUT, INPUT and or states fast enough. maybe writing the port registers directly would help.
thanks, red
Can you post a screen shot of your scope?
The time constant for your setup is resistance * capacitance. You may calculate it yourself with what new value of resistance you used. You are waiting 100 microseconds. If the time constant is not in the order of 20-30 microseconds, you are not giving enough time to charge. I saw your code, your charging is right. I’m yet to read the rest of your code.
I'm going to work on changing the code to use the port registers directly. from what i've read it makes the code a good deal faster and changes all the pins at once. i'm afraid the charge in the cap is draining before it can be test.
red
I don’t think that is writing right. because it doesn’t work. I changed the circuit and code a bit. I hope someone can understand the help me fix the problem.
here is the new circuit and code. thanks, red
// pin 10 C+ - 150 ohm resistor----------|------------|
// 3.3 nF cap 760 ohm to simulate Rx
// | Resistor
// pin 9 C- --------------------------------|
// pin 8 EC ---------------------------------------------|
void setup(){
void loop (){
//charge cap
DDRB = B110;
PORTB |= B100;
delayMicroseconds(50);
DDRB = B011;
PORTB = B000;
while (PINB & (1<<PINB2) == 1){ // while ill high loop on pin d10
timesThru += 1;
setDelay = timesThru * 10; //set delays down the line so feq has even phases
DDRB = B110;
PORTB = B000;
// the other side or the ac wave this side is unmeasured
DDRB = B111;
PORTB = B001;
PORTB = B000;
return timesThru;
No. You have no clue how many times this will loop BECAUSE YOU ARE NOT INITIALIZING the loop index.
Local variables, like i, are not given initial values by the compiler. YOU have to do that.
thanks, i shouldn't have miss that. It takes longer for the arduino to work thru that function now. i took the delay out of void loop(). the part i cant understand is how it doesnt seem to be charging the cap more than a 1 volt either way. i think i did the math right to figure out change times. that said it needs 1.5 microseconds to charge to like 87%. so 50 microseconds should be a huge overkill. i know i could put a large resistor in place of Rx but, i had a 5.6 M in there and still the same problem. i looked it up and water with TDS of 835 (in the range of TDS the final project would work in) only has the resistance of about 600 ohms. EC pin is set as a input at that point in the program so there shouldn't be any current bleeding thru the Rx resistor any ways, i dont know.
thanks, red
Hey Red, know it's been a while but I'm trying to build a TDS as well and I'm just a beginner.
Did you manage to do it? Could you give me a hand?
