water temperature data into mysql using ethernet shield
from reference http://www.tweaking4all.com/hardware/arduino/arduino-ethernet-data-push/#comment-31652
in this project i use: PC -OS Windows, Xampp, arduino UNO R3
i also make modification on 3 files php: dbconnect.php, add_data.php, review_data.php
------------------------------dbconnect.php-----------------------------------------------
<?php
$dbhost = 'localhost';
$dbuser = 'root'; //never use root user in live system
$dbpass = ''; // never use blank or simple password or password same as user name in live system
$conn = mysql_connect($dbhost, $dbuser, $dbpass) or die ('Error connecting to mysql');
$dbname = 'test';
mysql_select_db($dbname);
-------------------------add_data.php------------------------------------------------------
<?php
    // Connect to MySQL
    include("dbconnect.php");
    $counter=1;
    while ( isset( $_GET["serial".$counter] ) )
        // Prepare the SQL statement
        $SQL = "INSERT INTO test.temperature (sensor ,celsius) VALUES ('".$_GET["serial".$counter]."', '".$_GET["temperature".$counter]."')";
        // Execute SQL statement
        mysql_query($SQL);
        // Increase counter
        $counter++;
    // Go to the review_data.php
    header("Location: review_data.php");
--------------------------------review_data.php---------------------------------------------
<?php
    // Start MySQL Connection
    include('dbconnect.php');
<html>
<head>
    <title>Arduino Temperature Log</title>
    <style type="text/css">
        .table_titles, .table_cells_odd, .table_cells_even {
                padding-right: 20px;
                padding-left: 20px;
                color: #000;
        .table_titles {
            color: #FFF;
            background-color: #666;
        .table_cells_odd {
            background-color: #CCC;
        .table_cells_even {
            background-color: #FAFAFA;
        table {
            border: 2px solid #333;
        body { font-family: "Trebuchet MS", Arial; }
    </style>
</head>
    <body>
        <h1>Arduino Temperature Log</h1>
    <table border="0" cellspacing="0" cellpadding="4">
      <tr>
            <td class="table_titles">ID</td>
            <td class="table_titles">Date and Time</td>
            <td class="table_titles">Sensor Serial</td>
            <td class="table_titles">Temperature in Celsius</td>
          </tr>
<?php
    // Retrieve all records and display them
    $result = mysql_query("SELECT * FROM temperature ORDER BY id ASC");
    // Used for row color toggle
    $oddrow = true;
    // process every record
    while( $row = mysql_fetch_array($result) )
        if ($oddrow)
            $css_class=' class="table_cells_odd"';
            $css_class=' class="table_cells_even"';
        $oddrow = !$oddrow;
        echo '<tr>';
        echo '   <td'.$css_class.'>'.$row["id"].'</td>';
        echo '   <td'.$css_class.'>'.$row["event"].'</td>';
        echo '   <td'.$css_class.'>'.$row["sensor"].'</td>';
        echo '   <td'.$css_class.'>'.$row["celsius"].'</td>';
        echo '</tr>';
    </table>
    </body>
</html>
----------------------sketch on arduino-----------------------------------------------------------
#include <UIPEthernet.h> // Used for Ethernet
#include <OneWire.h>     // Used for temperature sensor(s)
// **** ETHERNET SETTING ****
// Arduino Uno pins: 10 = CS, 11 = MOSI, 12 = MISO, 13 = SCK
// Ethernet MAC address - must be unique on your network - MAC Reads T4A001 in hex (unique in your network)
byte mac[] = { 0x54, 0x34, 0x41, 0x30, 0x30, 0x31 };
// For the rest we use DHCP (IP address and such)
IPAddress server(192,168,1,2); // IP Adres (or name) of server to dump data to
int  interval = 1000; // Wait between dumps
IPAddress ip(192,168,1,3);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
EthernetClient client;
// **** TEMPERATURE SETTINGS ****
// Sensor(s) data pin is connected to Arduino pin 2 in non-parasite mode!
OneWire  ds(3);
  Serial.begin(19200);
   Ethernet.begin(mac, ip);
  Serial.println("Temperature Connection to Server");
  Serial.println("-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-\n");
  Serial.print("IP Address        : ");
  Serial.println(Ethernet.localIP());
  Serial.print("Subnet Mask       : ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("Default Gateway IP: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("DNS Server IP     : ");
  Serial.println(Ethernet.dnsServerIP());
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    client.connect(server, 80);
    Serial.println("-> Connected");
    // Make a HTTP request:
    //client.print( "GET /testserver/arduino_temperatures/add_data.php?");
    client.print( "GET /add_data.php?");
    TemperaturesToGetVariables(); // send serial and temperature readings
    client.println( " HTTP/1.1");
    client.println( "Host: 192.168.1.2" );
    client.print(" Host: ");
    client.println(server);
    client.println( "Connection: close" );
    client.println();
    client.println();
    client.stop();
    // you didn't get a connection to the server:
    Serial.println("--> connection failed!");
    client.stop();
    Ethernet.begin(mac, ip, gateway, subnet);
  delay(interval);
void TemperaturesToGetVariables(void) {
  byte counter;
  byte present = 0;
  byte sensor_type;
  byte data[12];
  byte addr[8];
  float celsius;
  byte sensorcounter;
  ds.reset_search();
  sensorcounter = 1; // we start counting with sensor number 1
  while ( ds.search(addr) )
    if (sensorcounter>1) client.print("&&"); // add ampersand if not first sensor
    client.print("serial"); // print: sensorx=
    client.print(sensorcounter);
    client.print("=");
    // Print Serial number
    Serial.print("   Sensor     : ");
    Serial.println(sensorcounter);
    Serial.print("   Serial     : ");
    for( counter = 0; counter < 8; counter++)
      if (addr[counter]<10) client.print("0");
      client.print(String(addr[counter], HEX));
      if (counter<7) client.print("%20");
      if (addr[counter]<10) Serial.print("0");
      Serial.print(String(addr[counter], HEX));
      if (counter<7) Serial.print(" ");
    client.print("&&temperature");  // print: &temperaturex=
    client.print("=");
    // Check CRC
    if (OneWire::crc8(addr, 7) != addr[7]) // print ERROR if CRC error
        client.println("ERROR");
    else // CRC is OK
        // Removed sensor type detection and assumed DS18B20 sensor
        ds.reset();
        ds.select(addr);
        ds.write(0x44);  // start conversion, with regular (non-parasite!) power
        delay(750);     // maybe 750ms is enough, maybe not
        present = ds.reset();
        ds.select(addr);
        ds.write(0xBE);  // Read Scratchpad
        // Get Raw Temp Data
        for ( counter = 0; counter < 9; counter++)
        {           // we need 9 bytes
          data[counter] = ds.read();
        // Convert the data to actual temperature
        int16_t raw = (data[1] << 8) | data[0];
        // at lower res, the low bits are undefined, so let's zero them
        byte cfg = (data[4] & 0x60);
        //// default is 12 bit resolution, 750 ms conversion time
        if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
        else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
        else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
        celsius = (float)raw / 16.0;
        client.print(celsius);
        Serial.print("   Temperature: ");
        Serial.print(celsius);
        Serial.println(" C");
     sensorcounter++;
  return;
the problem is i cant connect to mysql and connection always fail…
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
htdocs.rar (1.46 KB)
Are you sure your IP addresses are correct?
Try ethernet.begin without an IP in the hope that your router will give you one - at least it'll demonstrate that there's enough communication for DHCP to work.
If you successfully connect to the server, connect to the server. Why?
