Hey please im trying to build a water quality monitoring system. when i use the function send_sms();
i get the error 'send_sms' was not declared in this scope.
Im using an arduino Mega clone and sim900. can anyone tell me please why i get this error. Please
Apart from not seeing why your text wasn’t sent..*
I’d make the following suggestions…
Ask someone to help restructure and rewrite all your code.
Your use of delays anywhere is perplexing, along with repeated blocks of code and a glaring lack of understanding how or why you’ve use some pieces of code.
I know this is harsh, but when you repost your new code WITH CODE TAGS and proper indentation, it will become clearer to both of us.
*- I’ve written a lot of code, and while yours is decent for someone learning and experimenting, it’s nowhere good enough for an application to be used in earnest.
I would suggest your make a copy of your code and remove ALL code not related to SMS or find an example code for SMS.
Then trouble shoot it as a standalone. Once you get it to work combine it with your remaining functional code.
BTW If you haven't already, I would recommend you do the same thing with each device you are using. It will become much easier to troubleshoot.
Please edit your post to add code tags.
How did you get to such a large program, with such a basic, fundamental mistake?
The library was not properly included, or wrong library. Make sure you completely understand how the basic SMS examples work before creating a new program, and proceed to add features one step at a time, testing as you go.
