Waterdispenser with 2 supersonic sensors
Hello,
How do i combine 2 Arduino sketches for the supersonic sensor?
Theire are 2 senors that do the same thing only in diffrent places
1 sensor is left other sensor is 50 cm to the right
This is 1 sketch:
#define trigger 9
#define echo 8
#define LED 13
#define MOSFET 12
float time=0,distance=0;
pinMode(trigger,OUTPUT);
pinMode(echo,INPUT);
pinMode(LED,OUTPUT);
pinMode(MOSFET,OUTPUT);
measure_distance();
if(distance<5)
digitalWrite(LED,HIGH);digitalWrite(MOSFET,HIGH);
delay(10000);
digitalWrite(LED,LOW);digitalWrite(MOSFET,LOW);
void measure_distance()
digitalWrite(trigger,LOW);
delayMicroseconds(2);
digitalWrite(trigger,HIGH);
delayMicroseconds(10);
time=pulseIn(echo,HIGH);
distance=time*340/20000;
This is the second sketch:
#define trigger 7
#define echo 6
#define LED 13
#define MOSFET 12
measure_distance();
if(distance<5)
delay(25000);
Thanks in advance!
please take a minute and read How To Use This Forum
it can be found as a sticky post at the top of every forum
pay attention to #7 about how to use Code Tags
then come back, and on the bottom right of your post is the modify button
then put your code into code tags.
#2) can you post a link to the supersonic sensors ?
ASSUMING, that your code is working......
this is not working code, but the general idea.
you need to identify each part.
what is not done is the actual loop()
#define triggerleft 9
#define echoleft 8
#define LEDleft 13
#define MOSFET 12
#define triggeright 7
#define echoright 6
#define LEDright 13
//  #define MOSFET 12  // this is the same MOSFET for both
float timeR=0,distanceR=0;
float timeL=0,distanceL=0;
pinMode(triggerleft,OUTPUT);
pinMode(echoleft,INPUT);
pinMode(LEDleft,OUTPUT);
pinMode(triggerright,OUTPUT);
pinMode(echoright,INPUT);
pinMode(LEDright,OUTPUT);
//  pinMode(MOSFET,OUTPUT);
   void measure_distance();
//  your logic needs to go here
digitalWrite(triggerleft,LOW);
digitalWrite(triggerleft,HIGH);
timeL=pulseIn(echoleft,HIGH);
distanceL=timeL*340/20000;
digitalWrite(triggerright,LOW);
digitalWrite(triggerright,HIGH);
timeR=pulseIn(echo,HIGH);
distanceright=timeR*340/20000;
Putting a function prototype there is doing nothing at all useful.
Air temperature is the major factor in the speed of sound. It is faster on a hot day than in a cool night for instance.
No, density doesn't make the difference and humidity is a magnitude less factor than temperature. Check with NASA.
You could benefit by learning about arrays of variables.
I wonder if supersonic sensors produce a sonic boom when they pass by.
The more common ultrasound sensors don't.
