Waterproff UltraSonic
Can u Please provide me the programming logic of waterproof ultrasonic sensor for exact reading of data. M trying to detect the level of water but i could not get the exact data. So can u suggest me the logic for getting the exact data ...............
Could you post what you tried?
And what Arduino you are using and what sensor and its data sheet?
Borish:
How close to the "exact level" did you get? Is it within the error range for the device?
Paul
i tried the below code:
#define trigger 4
#define echo 5
float tim=0, distance = 0;
int temp = 0;
void setup{
pinMode(trigger,OUTPUT);
pinMode(echo,INPUT);
digitalWrite(trigger,LOW);
delayMicroseconds(2);
digitalWrite(trigger,HIGH);
delayMicroseconds(10);
tim=pulseIn(echo,HIGH);
distance=tim*340/20000;
Serial.print("Empty Space In ");
Serial.print("Tank is: ");
Serial.print(distance);
Serial.println(“cm”);
delay(2000);
if(distance<10 && temp==0)
Serial.println(“WATER TANK FULL”);
delay(2000);
temp = 1;
else if(distance<25 && temp==1)
Serial.println(“Water Tank Half”);
delay(5000);
else if(distance>40)
Serial.println(“Low water Tank”);
delay(5000);
temp = 0;
here in this code i am getting wrong data for sensor. please check it.
Where is your loop()?
