Waterproof ultrasonic sensor measurements problems
Hello, I have a problem with the measurements from the sensor because it no longer measures then 2.2 meters, but in the description it said that it measures about 5 meters. What can I change in the code ??
this is my code:
#define TRIGPIN 11
#define ECHOPIN 10
float duration, distance;
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(20);
duration = pulseIn(ECHOPIN, HIGH);
distance = (duration / 2) * 0.343;
Serial.print("distance: ");
Serial.print(distance);
Serial.println(" mm");
delay(100);
Your topic was MOVED to its current forum category as it is more suitable than the original
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Your code is incomplete and lacks code tags.
(pulseIn does not return a float, and you told us nothing about your sensor other than it might be waterproof)
You can post code by using this method that adds the code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
