WattHour Meter Lag 6Watts / Minute
I Try to Build a Power Consumption meter For my e-Bike With Arduino and Blynk to find out remaining charge left in my. I Try to Calculate the Power every Quarter of a second and Add it to The BalanceWatts .
I Can Calculate Everything Except Watt Hour / 250 Microseconds
#include "SimpleTimer.h"
#include <BlynkSimpleSerialBLE.h>
#define voltPIN 6
#define ampPIN 7
char auth[] = "404212715de241cd977f7c2f98e00a10";
// i Choose float for every variable because if i choose int for any of the following it return wrong result
float adcVolt,adcAmp,Volt,Amp,Watt,wattPerQuatersecond;
float balanceWatt = 1780;   // Battery Capacity at Full charge
float refVolt = 5.00;
float ampOffset = 2500;
float milliPerAmp = 66.00;   // ACS712 Referece
float R1=147000;             // 147k
float R2=10000;              // 10k arduino output impedance match
SimpleTimer myTimer;
WidgetLCD lcd(5);       // Blynk LCD Widget Initiate
        pinMode(voltPIN, INPUT);
        pinMode(ampPIN,INPUT);
        Blynk.begin(Serial,auth);
        lcd.clear();
        myTimer.setInterval(250,calculate);  // do job every Quater of a secand
        Blynk.run();
        myTimer.run();
    void calculate()
      adcVolt = 900 ; // Tempravory Value
      adcAmp = 200;   // Temp value
      float readVolt = ((adcVolt * refVolt) / 1024.00);
       Volt = readVolt/(R2/(R1+R2));
      float readAmp =  (((adcAmp * 5020.00)/1024.00) - ampOffset);           // INSTEAD OF 5000 I PUT 5020 (20) FOR CORRECTION IN AMPS
       Amp = readAmp / milliPerAmp;
       Watt = (Volt * Amp); // 1500 W
       wattPerQuatersecond = (Watt / (3600.00*4)); // 0.110W/quaterSecand
       balanceWatt = balanceWatt - wattPerQuatersecond;
        Blynk.virtualWrite(1, Volt);     //Gauge 1
        Blynk.virtualWrite(2, Amp);
        Blynk.virtualWrite(3, Watt);
        Blynk.virtualWrite(4, balanceWatt);  // Gauge 4
According to my Code every if my Hub motor consume 1500W then Watt per Quarter Seconds is
1500 / (3600 X 4) = 0.110W/quarterSecand
After one Minute my Battery Balance Power must increased to 1780 + (0.110460) = 1780 + 26.4 = 1806.4
But The Display Shows 1800. and Every Minute it Lag 6W . I Try to Solve this problem From the Last Week but I cannot find out my mistake. please anyone point out my problem and help me to solve. sorry for my bad English,
I Attach my code with this post
// ACS 712 Takes 200 as -27Amps (Reverse Current as Battery Get Charge From a Charger )
Forum_watt_6W_error.ino (1.73 KB)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
TomGeorge:
Thanks Tom , I edit My post according to the rule you mentioned.
I'm not sure but if
you should;
float ampOffset = 2500.0;
You have defined quite a few variables without decimal point.
Worth a try.
Where are you using " void calculate() "
Tom... :slight_smile:
[/quote]
Problem Solved . Thankyou so much Sir, you Really Save my lots of Time . and one more thing why need to put 2500.00 instead of 2500.
I read about int and float mathematical operation that shows float of int and float is return float . then why this mistakes. me
Worth a try.
I change all the integer values to float .
#define voltPIN 6
#define ampPIN 7
float balanceWatt = 1780.00;   // Battery Capacity at Full charge
float ampOffset = 2500.00;
float R1=147000.00;             // 147k
float R2=10000.00;              // 10k arduino output impedance match
        lcd.clear();
        Blynk.run();
        myTimer.run();
    void calculate()
      adcVolt = 900.00 ; // Tempravory Value
      adcAmp = 200.00;   // Temp value
       wattPerQuatersecond = (Watt / (3600.00*4.00)); // 0.110W/quaterSecand
PROBLEM COMES AGAIN IF I ADD TIMER WITH ABOVE PROGRAM , WITH OUT myClock() Function it Works Perfect. Any Suggestions ?
#include <DHT.h>
#include <EEPROM.h>
#define VOLTPIN 6
#define AMPPIN 7
#define DHTPIN 12
#define DHTTYPE DHT11
float adcVolt,adcAmp,Volt,Amp,Watt,wattPerQuaterSecand;
float R1=147000.00;
float R2=10000.00;
float Fahrenheit = 0.00;
 unsigned long timeSecands = 0;
 unsigned long timeMinutes = 0;
 unsigned long timeHours = 0;
WidgetLCD lcd(5);
DHT dht(DHTPIN, DHTTYPE);
        pinMode(VOLTPIN, INPUT);
        pinMode(AMPPIN,INPUT);
        balanceWatt = EEPROMReadint(0);
        lcd.clear();
        myTimer.setInterval(1000,myClock);
        myTimer.setInterval(5000,boardTemp);
        myTimer.setInterval(10000,updateEEPROM);
        Blynk.run();
        myTimer.run();
 void calculate()
       unsigned int sampleVolt = 0;
       unsigned int sampleAmp = 0;
      for(int v=0;v<50;v++)
           sampleVolt = sampleVolt+analogRead(VOLTPIN);   //50 samples for voltage
           sampleAmp = sampleAmp+analogRead(AMPPIN);     //50 samples for current
         adcVolt =  sampleVolt / 50;               //average voltage
         adcAmp =   sampleAmp / 50;                //average current
      float readVolt = ((adcVolt * refVolt) / 1023.00);
      float readAmp =  (((adcAmp * 5000.00)/1023.00) - ampOffset);            //INSTEAD OF 5000 I PUT 5020 (20) FOR CORRECTION IN AMPS
       wattPerQuaterSecand = (Watt / (3600.00*4.00));
       balanceWatt = balanceWatt - wattPerQuaterSecand;
       lcd.print(1,1,balanceWatt);
 void myClock()
        timeSecands ++;
        timeMinutes = timeSecands / 60;
        timeHours = timeMinutes / 60;
            lcd.print(8,0,(timeHours%24)/10);
            lcd.print(9,0,timeHours%4);
              lcd.print(10,0,":");
            lcd.print(11,0,(timeMinutes%60)/10);
            lcd.print(12,0,timeMinutes%10);
              lcd.print(13,0,":");
            lcd.print(14,0,(timeSecands%60)/10);
            lcd.print(15,0,timeSecands%10);
 void boardTemp()
           Fahrenheit = dht.readTemperature(true);
           Blynk.virtualWrite(7, Fahrenheit);
 void updateEEPROM()
        EEPROMWriteint(0,balanceWatt);
        Blynk.virtualWrite(4, (int)balanceWatt);
 void EEPROMWriteint(int address, int value)
 // Decomposition from a long to 2 bytes by using bitshift.
 // One = Most significant -> Four = Least significant byte
      byte two = (value & 0xFF);
      byte one = ((value >> 8) & 0xFF);
 // Write the 2 bytes into the eeprom memory.
      EEPROM.write(address, two);
      EEPROM.write(address + 1, one);
int EEPROMReadint(int address)
   // Read the 2 bytes from the eeprom memory.
        long two = EEPROM.read(address);
        long one = EEPROM.read(address + 1);
   // Return the recomposed long by using bitshift.
      return ((two << 0) & 0xFF) + ((one << 8) & 0xFFFF);
