Hi there,
I have 3 ultrasonic sensors set up on an arduino uno that are working as expected. In each of my if loops, I would like to play a track.
if (OrangeSensor < 39) {
Serial.print("orange - small ");
Serial.print(OrangeSensor);
//wTrig.trackPlayPoly(01); // Start Track 16 poly
//delay(10000);
//digitalWrite(play, LOW);
I am currently struggling to connect the WAV trigger correctly - I am using different bits of code found from different forums
- the libraries have been included correctly
- the wav board is connect to a 12v power supply
- it's grounded
- TX is in pin 9
Questions
- there are currently 3 tracks on the SD card names 0001.wav, 0002.wav and 0003.wav. I am unsure where to define these
- with the code I have I would expect that on startup I can at least hear the 1st track
using; wTrig.trackPlayPoly(01); I cannot - do I need to code in that the TX pin is connected to digital 9?
Many thanks in advance
//https://www.theengineeringprojects.com/2015/02/interfacing-multiple-ultrasonic-sensor-arduino.html
//sucessfully added second sensor - one sensor controls lights, the other sound (and light)
//attempting to add WAV trigger
// to add libraries from github; navigate to folder and use git clone on master branch
#include <AltSoftSerial.h> // Arduino build environment requires this
#include <wavTrigger.h>
//#include <metro.h> // no idea
wavTrigger wTrig; // Our WAV Trigger object
//ORANGE
#define trigPin1 7
#define echoPin1 6
//PINK
#define trigPin2 11
#define echoPin2 12
//BLUE
#define trigPin3 8
#define echoPin3 5
long duration, distance, OrangeSensor,PinkSensor, BlueSensor;
Serial.begin (9600);
// If the Arduino is powering the WAV Trigger, we should wait for the WAV
// Trigger to finish reset before trying to send commands.
//delay(1000);
// WAV Trigger startup at 57600
wTrig.start();
delay(10);
// Send a stop-all command and reset the sample-rate offset, in case we have
// reset while the WAV Trigger was already playing.
wTrig.stopAllTracks();
wTrig.samplerateOffset(0);
Serial.print("we've started");
delay(100);
//Serial.print(BlueSensor);
//set orange sensor
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
//set pink sensor
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
//set blue sensor
pinMode(trigPin3, OUTPUT);
pinMode(echoPin3, INPUT);
//orange sensor
SonarSensor(trigPin1, echoPin1);
OrangeSensor = distance;
//pink sensor
SonarSensor(trigPin2, echoPin2);
PinkSensor = distance;
//blue sensor
SonarSensor(trigPin3, echoPin3);
BlueSensor = distance;
//Serial.print("Orange - " + String(OrangeSensor));
/*Serial.print("Orange Sensor");
Serial.print(" - ");
Serial.println(OrangeSensor);
Serial.print("Pink Sensor");
Serial.println(PinkSensor);
Serial.println("===========");*/
//orange loop
//delay(10000);
} else if ((OrangeSensor > 40) && (OrangeSensor < 99)) {
Serial.print("orange - medium ");
} else if ((OrangeSensor > 100) && (OrangeSensor < 150)) {
Serial.print("orange - large");
//digitalWrite(play, LOW); // dont play recording
// pink loop
if (PinkSensor < 39) {
Serial.print("pink - small ");
Serial.print(PinkSensor);
} else if ((PinkSensor > 40) && (PinkSensor < 99)) {
Serial.print("Pink - medium ");
} else if ((PinkSensor > 100) && (PinkSensor < 150)) {
Serial.print("Pink - large");
//blue loop
if (BlueSensor < 39) {
Serial.print("blue - small ");
} else if ((BlueSensor > 40) && (BlueSensor < 99)) {
} else if ((BlueSensor > 100) && (BlueSensor < 150)) {
Serial.print("Blue - large");
//no idea why this doesn't work
else if ((OrangeSensor >151) && (PinkSensor >151) ) {
//placed here to pevent LEDs constantly flickering
Serial.print('no one is within the paremeters ');
//digitalWrite(play, LOW); // player off
void SonarSensor(int trigPin,int echoPin)
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
