wave shield problem
Ok, might be super noob question here, but here goes...
Got a wav file loaded up to my sd card and everything connected, but it won't play?
I checked the COM window and I can see the program running, but when it gets to the wav file it says "invalide wav file" and the name of the file. I am running the loop example so it does this over and over.
I have the sd card formatted in FAT and the file is just a recording I did from the computers microphone.
Long story short the program sees the file, lists it by name, but will not play it.
Any help or direction will be greatly appreciated.
I would recommend using a ready-made example wav file. I think there are some on the site somewhere. Try a few files that you didn't record as it may be the bitrate of your wav file or something. I have not used the wav shield so I probably can't be of much help otherwise.
Mowcius
Thanks, I will try that. Wonder what a good mp3 converter program would be?
Any suggestions?
Not a clue!
The wav shield cannot do great audio even if you get an MP3 converted. The rMP3 shield is much better for that.
Mowcius
I want to make a motion activated talking skeleton for Halloween. Saw it on instructables. Looks pretty cool.
One thing about it the servo seems to be out of sync with the voice. Wonder how to fix that?
