Wave Shield with keypad?
Looking at the Wavehc library example of “Play the wave file all the way through once, but allow other buttons to interrupt”, I am having trouble understanding where it is defining the pins for the buttons?
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {14, 15, 16, 17, 18, 19};
What do these numbers represent? Last time i checked I don’t have 19 digital pins :slight_smile: any guidance?
Here is the full example:
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
FatReader f;      // This holds the information for the file we're play
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
#define DEBOUNCE 5  // button debouncer
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'pressed' (the current state
volatile byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
  byte i;
  // set up serial port
  putstring_nl("WaveHC with ");
  Serial.print(NUMBUTTONS, DEC);
  putstring_nl("buttons");
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
  pinMode(13, OUTPUT);
  // Make input & enable pull-up resistors on switch pins
  for (i=0; i< NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT);
    digitalWrite(buttons[i], HIGH);
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
// Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Ready!");
  TCCR2A = 0;
  TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  byte index;
  for (index = 0; index < NUMBUTTONS; index++) {
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
  byte i;
  if (justpressed[0]) {
    justpressed[0] = 0;
    playfile("DO.WAV");
  else if (justpressed[1]) {
      justpressed[1] = 0;
      playfile("RE.WAV");
  else if (justpressed[2]) {
      justpressed[2] = 0;
      playfile("MI.WAV");
  else if (justpressed[3]) {
      justpressed[3] = 0;
      playfile("FA.WAV");
  else if (justpressed[4]) {
      justpressed[4] = 0;
      playfile("SO.WAV");
  else if (justpressed[5]) {
      justpressed[5] = 0;
      playfile("LA.WAV");
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
  // call our helper to find and play this name
  playfile(name);
  while (wave.isplaying) {
  // do nothing while its playing
  // now its done playing
void playfile(char *name) {
  // see if the wave object is currently doing something
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  // look in the root directory and open the file
  if (!f.open(root, name)) {
    putstring("Couldn't open file "); Serial.print(name); return;
  // OK read the file and turn it into a wave object
  if (!wave.create(f)) {
    putstring_nl("Not a valid WAV"); return;
  // ok time to play! start playback
  wave.play();
Check again, then.
If you have a Duemilanove (or other variation with 13 digital pins and 6 analog pins), the analog pins can be used as digital pins. They are numbered 14 through 19.
It all makes sense now! Thanks Paul.
Now I am trying to use a keypad, and the keypad library (http://www.arduino.cc/playground/Code/Keypad)
in conjunction with the wave shield.
I am having a little trouble wrapping my head around the best approach, since the waveshield button example is by default looking for “low/high” with the buttons, whereas when using a matrixed keypad, it doesn’t seem to work that way. It seems that using addEventListener(keypadEvent) and if statements containing the command to play the respective wav file would be logical?
Here is an example of keypad events:
#include <Keypad.h>
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these pins,
// eg. ROW0 = Arduino pin2.
byte rowPins[] = { 9, 8, 7, 6 };
// Connect keypad COL0, COL1 and COL2 to these pins,
// eg. COL0 = Arduino pin6.
byte colPins[] = { 12, 11, 10 };
//create a new Keypad
Keypad keypad = Keypad(rowPins, colPins, sizeof(rowPins), sizeof(colPins));
#define ledPin 13       // Use the LED on pin 13
  digitalWrite(ledPin, HIGH);   // sets the LED on
  keypad.addEventListener(keypadEvent); //add an event listener
  keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey) {
  switch (eKey) {
  case '*':
  case '#':
    digitalWrite(ledPin, LOW);
  case KEY_RELEASED:
    Serial.println("Key Released");
  default:
    if (eKey) {      // same as if(eKey != NO_KEY)
      Serial.println(eKey);
and then there is the waveshield button example (this one in particular is where it plays the file once, and allows for other buttons to interrupt):
#include "WaveHC.h"
byte buttons[] = {14, 15, 16, 17, 18, 19};  // =====================================================================================================
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
  byte i;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
  check_switches();
  byte index;
          // just pressed
          // just released
  byte i;
    justpressed[0] = 0;
    playfile("DO.WAV");
      justpressed[1] = 0;
      playfile("RE.WAV");
      justpressed[2] = 0;
      playfile("MI.WAV");
      justpressed[3] = 0;
      playfile("FA.WAV");
      justpressed[4] = 0;
      playfile("SO.WAV");
      justpressed[5] = 0;
      playfile("LA.WAV");
  playfile(name);
  wave.play();
update: I’ve cobbled together a combination of using the keypad and waveshield, and feel like this should work, but I am getting the following errors?
5: error: variable or field 'keypadEvent' declared void
5: error: 'KeypadEvent' was not declared in this scope
79: error: expected unqualified-id before 'if'
from
#include "WaveHC.h"
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
  byte i;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  byte i;
   char key = keypad.getKey();
  if (key != NO_KEY) {
    Serial.println(key);
  if (blink){
    digitalWrite(ledPin,!digitalRead(ledPin));
    delay(100);
void keypadEvent(KeypadEvent key){
  switch (keypad.getState()){
    case PRESSED:
      switch (key){
        case '1': playfile("DO.WAV");
update 2: the first two errors were due to me being a n00b - included the keypad lib in the wrong spot
it is still complaining about: 78: error: expected unqualified-id before 'if’
which would be line: ** if (!card.init()) { //play with 8 MHz spi (default faster!) **
so clearly I’m missing some component of the waveshield setup? anything pop out?
#include "WaveHC.h"
#include <Keypad.h>
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
  byte i;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
  byte i;
  if (blink){
    delay(100);
    case PRESSED:
      switch (key){
Executable code needs to be in a function body. Putting opening and closing curly braces on separate lines, and consistently indenting code between them would show you where the setup() function ended. You have a lot of code after that point. Line 78 is the first such line.
For anyone interested: I got it working! Aside from visually tidying, and commenting, how might you recommend optimizing this? All in all it works flawlessly. In all of my googling I wasn’t able to find any sketches using a matrixed keypad with the waveshield, so this is potentially useful to others.
#include "WaveHC.h"
#include <Keypad.h>
// keypad setup
const byte ROWS = 3; //four rows
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'}
byte rowPins[ROWS] = {14, 15, 16}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {17, 18, 19}; //connect to the column pinouts of the keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// end keypad setup
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
  byte i;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
   //   return;
 // TIMSK2 |= 1<<TOIE2;
  char key = kpd.getKey();
  if(key)  // same as if(key != NO_KEY)
    switch (key)
      case '1':
       playfile("DTMF1.WAV");
        case '2':
       playfile("DTMF2.WAV");
        case '3':
       playfile("DTMF3.WAV");
        case '4':
       playfile("DTMF4.WAV");
         case '5':
       playfile("DTMF5.WAV");
         case '6':
       playfile("DTMF6.WAV");
         case '7':
       playfile("DTMF7.WAV");
        case '8':
       playfile("DTMF8.WAV");
        case '9':
       playfile("DTMF9.WAV");
      default:
  playfile(name);
  wave.play();
