system
1
i bought this from waveshare . http://www.wvshare.com/product/0.96inch-OLED-A.htm
the oled display is based on SSD1306 . need some help to connect it with arduino
Post on arduino stackexchange : i2c - need help hooking up an oled display - Arduino Stack Exchange
thanks
Hi
The display should work with U8glib. In the U8glib documentation, D/C is often refered as A0.
I suggest to use 4-wire SPI.
Oliver
system
3
Thanks i was able to make it work with u8glib library using 4-wire SPI
using the following constructor
U8GLIB_SSD1306_128X64 u8g(13, 11, 10, 9,8);
Pin configuration was
| Arduino |
Oled Display |
| 13 |
CLK |
| 11 |
DIN (SI) |
| 10 |
CS |
| 9 |
D/C (A0) |
| 8 |
RES |
the reset pin is required . i used 3.3v arduino pin for vcc .
