Waveshare 1.28" Round LCD error
Can anyone throw light on what might be causing this error?
Round Waveshare 1.28" LCD connected to an Uno. Connections are correct according to several online sources (plus I connected it like this last time).
Just throws this error and I don't know why
#include <Wire.h>
#include <SPI.h>
#include <Arduino_GFX_Library.h>
#define TFT_CS 10        // Set up the screen SPI pins
#define TFT_DC 7
#define TFT_RST 8
#define TFT_BL 9
Arduino_DataBus *bus = new Arduino_HWSPI(TFT_DC, TFT_CS);
Arduino_GFX *gfx = new Arduino_GC9A01(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
  #define BLACK           0x0000
  #define BLUE            0x001F
  #define RED             0xF800
  #define GREEN           0x07E0
  #define CYAN            0x07FF
  #define MAGENTA         0xF81F
  #define YELLOW          0xFFE0
  #define WHITE           0xFFFF
int colours[] = {0x0000, 0x001F, 0xF800, 0x07E0, 0x07FF, 0xF81F, 0xFFE0, 0xFFFF};
  Wire.begin();
    pinMode(TFT_BL, OUTPUT);
  gfx->begin();
  gfx->fillCircle(120, 120, 120, BLACK);                                                  // Fill screen
  digitalWrite(TFT_BL, HIGH);                                                             // Turn on the backlight
  gfx->fillCircle(120, 120, 120, CYAN);
In file included from C:\Users\steve\Documents\Arduino\libraries\GFX_Library_for_Arduino\src/Arduino_GFX_Library.h:31:0,
                 from C:\Users\steve\Documents\Arduino\Happy Hunter\Transmitter_code_v1\Transmitter_code_v1.ino:13:
C:\Users\steve\Documents\Arduino\libraries\GFX_Library_for_Arduino\src/databus/Arduino_XL9535SWSPI.h:34:8: error: 'void Arduino_XL9535SWSPI::writeBytes(uint8_t*, uint32_t)' marked 'override', but does not override
   void writeBytes(uint8_t *data, uint32_t len) override;
C:\Users\steve\Documents\Arduino\libraries\GFX_Library_for_Arduino\src/databus/Arduino_XL9535SWSPI.h:35:8: error: 'void Arduino_XL9535SWSPI::writePattern(uint8_t*, uint8_t, uint32_t)' marked 'override', but does not override
   void writePattern(uint8_t *data, uint8_t len, uint32_t repeat) override;
exit status 1
Error compiling for board Arduino Uno.
The wiring is completely irrelevant at this point. The code won't even upload to the Arduino because it won't compile.
Did you test the display with one of the example sketches that comes with the library? It's always good to test like this before testing your own code.
The library github page suggests an example code called PDQgraphicstest.
If the example code won't compile, either something went wrong when you installed the library or there is a bug in the library.
The GC9A01.h library (which this screen uses) uploads..... but the screen doesn't work.
Tried a new second one... that doesn't work either
Its going to be one of 'those' projects
It's the UNO :roll_eyes:
Of all the things I didn't think it would be
