So I have this screen which i believe to be the version 2 which is 648x480 None of the 5.83 profiles will work. I was able to get the GxEPD2_3C<GxEPD2_750c_Z08 to control the screen. Text works perfectly and the 3 colors work fine. Images are another story. It could be they are just sized wrong. I even tried the code from waveshare and still couldnt get it to work.
So this is your issues? You need to be more specific. What did you try and what was the result.
I see that GxEPD2_Example has no test or code for 648x480 3-color bitmaps. I don't consider this as an issue, but might improve this if I find example bitmaps from Waveshare or Good Display.
The issue is the display does not respond to anything useing the 5.83 constructor. I did get text to work useing GxEPD2_3C<GxEPD2_750c_Z08 constructor. My question is. Will useing the wrong one do any damage or anything to screen. I can create the images myself. Just wanted to know if i was on the right track.
Image data from waveshare is here
I don't have that panel nor that Waveshare display. Therefore it is not supported by GxEPD2.
I don't know, but I don't expect. Parameters may be wrong, but waveform and driving voltages are taken from OTP, so I don't expect ghosting (sort of burn-in) or lasting ghosting.
