Waveshare 7.5in E-Ink Display not displaying example code with ESP32 Driver Board for me
LInk to Waveshare 7.5in E-Ink display (V2): https://www.amazon.com/dp/B07Z25LWTS?psc=1&ref=ppx_yo2ov_dt_b_product_details
Link to Driver Board: https://www.amazon.com/dp/B07M5CNP3B?psc=1&ref=ppx_yo2ov_dt_b_product_details
Attempted to use GxEPD2 starter Example code, getting this "busy timeout!" repeated message:
Busy Timeout!
_PowerOn : 10001048
Busy Timeout!
_Update_Full : 10001036
Busy Timeout!
_PowerOff : 10001036
Reading other forums, I have this line of code uncommented (however the issue is not resolved):
display.init(115200, true, 2, false);
I have also uncommented this line for the driver class:
#define GxEPD2_DRIVER_CLASS GxEPD2_750_T7
On the demo code given from Waveshare, I have an issue where the code is stuck on epd.init() in the .ino file:
    Epd epd;
    Serial.print("e-Paper init \r\n ");
    if (epd.Init() != 0) { //stuck on this line
        Serial.print("e-Paper init failed\r\n ");
        return;
I want to note that I am using the adapter connection from the display to the driver board instead of manually wiring to the driver board. Unsure if this would cause an issue. Would appreciate any help, thank you!
Hi @dpear5 , welcome to the forum!
Ok, I had breakfast, so I should be ready to answer posts as kindly as I can.
Please take a look at some comments in the example GxEPD2_Example.ino.
// NOTE for use with Waveshare ESP32 Driver Board:
// **** also need to select the constructor with the parameters for this board in GxEPD2_display_selection_new_style.h ****
// The Wavehare ESP32 Driver Board uses uncommon SPI pins for the FPC connector. It uses HSPI pins, but SCK and MOSI are swapped.
// To use HW SPI with the ESP32 Driver Board, HW SPI pins need be re-mapped in any case. Can be done using either HSPI or VSPI.
// Other SPI clients can either be connected to the same SPI bus as the e-paper, or to the other HW SPI bus, or through SW SPI.
// The logical configuration would be to use the e-paper connection on HSPI with re-mapped pins, and use VSPI for other SPI clients.
// VSPI with standard VSPI pins is used by the global SPI instance of the Arduino IDE ESP32 package.
You might also find the example for the Waveshare ESP32 driver board:
GxEPD2_WS_ESP32_Driver.ino
I hope this gets you started. Good Luck!
-jz-
Could you please change the title of your topic
from "Waveshare 7.5in E-Ink Display not displaying example code with ESP32 Driver Board"
to "Waveshare 7.5in E-Ink Display not displaying example code with ESP32 Driver Board for me"
this would be less offending and more correct. Thank you.
@dpear5 , thank you for the update of your topic title!
If you need further help, I would need to know the inking you see on the flexible connector of the display panel. Then I can guess if your display is supported by GxEPD2, and which driver class to use. There are two driver classes for the resolution of your panel.
I assume I understand this correctly: you use the connection to the FPC connector of the ESP32 driver board. You could post a picture of your setup. Some FPC connectors connect on the upper and on the lower side, some (earlier ones) don't. The ones with the rotating lever usually connect both sides, the ones with the sliding lever don't.
-jz-
Hey @ZinggJM , Really appreciate the help, It looks like my display is actually displaying something after uncommenting the HSPI lines. I believe this has occurred during leaving it idle for a while, but confirming currently.. Here is my setup:
After Re-uploading however, I am not getting any updates or restarts from the screen, with the "hibernating ... again" staying on the screen. Here is what I am seeing on the Serial Monitor:
Busy Timeout!
_PowerOn : 10000042
Busy Timeout!
_Update_Part : 10000037
Busy Timeout!
_Update_Part : 10000043
Busy Timeout!
_Update_Part : 10000042
Busy Timeout!
_Update_Full : 10000036
My first guess is wrong position of the RESE switch. It should be 0.47 ohms for this panel. This would be position B I think. I would need to consult the schematics to be sure. Try both positions, doesn't harm. Make sure your USB supply is strong enough.
Try also with GDEY075T7, I just have this display in front of me, looking same:
//#define GxEPD2_DRIVER_CLASS GxEPD2_750_GDEY075T7  // GDEY075T7  800x480, UC8179 (GD7965), (FPC-C001 20.08.20)
-jz-
Appreciate this, it seems like the only possible issue is the Voltage then, which I will have to get a multimeter to verify. (I have tried different power supplies including my desktop and laptop). I have tried both A and B configurations, on the documentation it is saying to use A or 0.47 Ohms. Let me know if you believe there could be another issue. Wish I could add an attachment to my code, but here is the code that I have so far for reference:
GxEPD2_Example.ino setup code:
// uncomment next line to use HSPI for EPD (and e.g VSPI for SD), e.g. with Waveshare ESP32 Driver Board
#define USE_HSPI_FOR_EPD
// base class GxEPD2_GFX can be used to pass references or pointers to the display instance as parameter, uses ~1.2k more code
// enable or disable GxEPD2_GFX base class
#define ENABLE_GxEPD2_GFX 0
#define ESP32
// uncomment next line to use class GFX of library GFX_Root instead of Adafruit_GFX
//#include <GFX.h>
// Note: if you use this with ENABLE_GxEPD2_GFX 1:
//       uncomment it in GxEPD2_GFX.h too, or add #include <GFX.h> before any #include <GxEPD2_GFX.h>
#include <GxEPD2_BW.h>
#include <GxEPD2_3C.h>
#include <GxEPD2_4C.h>
#include <GxEPD2_7C.h>
#include <Fonts/FreeMonoBold9pt7b.h>
// select the display constructor line in one of the following files (old style):
// #include "GxEPD2_display_selection.h"
// #include "GxEPD2_display_selection_added.h"
// or select the display class and display driver class in the following file (new style):
#include "GxEPD2_display_selection_new_style.h"
#if !defined(__AVR) && !defined(STM32F1xx)
// note 16.11.2019: the compiler may exclude code based on constant if statements (display.epd2.panel == constant),
//                  therefore bitmaps may get optimized out by the linker
// comment out unused bitmaps to reduce code space used
#include "bitmaps/Bitmaps800x480.h" // 7.5"  b/w
#if defined(ESP8266) || defined(ESP32) || defined(ARDUINO_ARCH_RP2040)
#endif
#if defined(ESP32) || defined(ARDUINO_ARCH_RP2040)
#endif
#else
// select only one to fit in code space
#include "bitmaps/Bitmaps800x480.h" // 7.5"  b/w // not enough code space
#endif
#if defined(ARDUINO_ARCH_RP2040) && (defined(ARDUINO_RASPBERRY_PI_PICO) || defined(ARDUINO_RASPBERRY_PI_PICO_W))
#if defined(__MBED__)
// SPI pins used by GoodDisplay DESPI-PICO. note: steals standard I2C pins PIN_WIRE_SDA (6), PIN_WIRE_SCL (7)
// uncomment next line for use with GoodDisplay DESPI-PICO. // MbedSPI(int miso, int mosi, int sck);
arduino::MbedSPI SPIn(4, 7, 6); // need be valid pins for same SPI channel, else fails blinking 4 long 4 short
// uncomment next line for use with my proto board. // MbedSPI(int miso, int mosi, int sck);
//arduino::MbedSPI SPIn(4, 3, 2); // need be valid pins for same SPI channel, else fails blinking 4 long 4 short
// uncomment next line for use with Waveshare Pico-ePaper-2.9. // MbedSPI(int miso, int mosi, int sck);
// note: doesn't work with Waveshare PhotoPainter, conflict on pin 12. use philhower package instead.
//arduino::MbedSPI SPIn(12, 11, 10); // need be valid pins for same SPI channel, else fails blinking 4 long 4 short
#else // package https://github.com/earlephilhower/arduino-pico
// SPIClassRP2040(spi_inst_t *spi, pin_size_t rx, pin_size_t cs, pin_size_t sck, pin_size_t tx);
//SPIClassRP2040 SPIn(spi0, 4, 5, 2, 3); // need be valid pins for same SPI channel, else fails blinking 4 long 4 short
// uncomment next line for use with Waveshare Pico-ePaper-2.9 or Waveshare PhotoPainter module
SPIClassRP2040 SPIn(spi1, 12, 13, 10, 11); // need be valid pins for same SPI channel, else fails blinking 4 long 4 short
#endif
#endif
#if defined(ESP32) && defined(USE_HSPI_FOR_EPD)
SPIClass hspi(HSPI);
#endif
  Serial.println("setup");
  delay(100);
  // uncomment next line for use with GoodDisplay DESPI-PICO or my proto board, or Waveshare RPi boards
  display.epd2.selectSPI(SPIn, SPISettings(4000000, MSBFIRST, SPI_MODE0));
  // uncomment next 2 lines to allow recovery from configuration failures
  pinMode(15, INPUT_PULLUP); // safety pin
  while (!digitalRead(15)) delay(100); // check safety pin for fail recovery
  // recovery can be done also by holding BOOTSEL during power-up.
  // uncomment next line for Waveshare PhotoPainter module
  pinMode(16, OUTPUT); digitalWrite(16, HIGH); // power to the paper
#endif
  hspi.begin(13, 12, 14, 15); // remap hspi for EPD (swap pins)
  display.epd2.selectSPI(hspi, SPISettings(4000000, MSBFIRST, SPI_MODE0));
#elif (defined(ARDUINO_ARCH_ESP32) && defined(ARDUINO_LOLIN_S2_MINI))
  // SPI.begin(sck, miso, mosi, ss); // preset for remapped pins
  SPI.begin(18, -1, 16, 33); // my LOLIN ESP32 S2 mini connection
#endif
  //display.init(115200); // default 10ms reset pulse, e.g. for bare panels with DESPI-C02
  display.init(115200, true, 2, false); // USE THIS for Waveshare boards with "clever" reset circuit, 2ms reset pulse
  //display.init(115200, true, 10, false, SPIn, SPISettings(4000000, MSBFIRST, SPI_MODE0)); // extended init method with SPI channel and/or settings selection
  if (display.pages() > 1)
    delay(100);
    Serial.print("pages = "); Serial.print(display.pages()); Serial.print(" page height = "); Serial.println(display.pageHeight());
  // first update should be full refresh
  helloWorld();
  // partial refresh mode can be used to full screen,
  // effective if display panel hasFastPartialUpdate
  helloFullScreenPartialMode();
  //stripeTest(); return; // GDEH029Z13 issue
  helloArduino();
  helloEpaper();
  //helloValue(123.9, 1);
  //delay(1000);
  showFont("FreeMonoBold9pt7b", &FreeMonoBold9pt7b);
  if (display.epd2.WIDTH < 104)
    showFont("glcdfont", 0);
  //drawGrid(); return;
  drawBitmaps();
  drawGraphics();
  //return;
#if !defined(__AVR) // takes too long!
  if ((display.epd2.panel == GxEPD2::ACeP565) || (display.epd2.panel == GxEPD2::GDEY073D46) || (display.epd2.panel == GxEPD2::ACeP730))
    //draw7colorlines();
    //delay(2000);
    draw7colors();
    delay(4000);
    //return;
#endif
  if (display.epd2.hasPartialUpdate)
    showPartialUpdate();
  } // else // on GDEW0154Z04 only full update available, doesn't look nice
  //drawCornerTest();
  //showBox(16, 16, 48, 32, false);
  //showBox(16, 56, 48, 32, true);
  display.powerOff();
  deepSleepTest();
#if defined(ESP32) && defined(_GxBitmaps1304x984_H_)
  drawBitmaps1304x984();
  display.powerOff();
#endif
  Serial.println("setup done");
  display.end();
GxEPD2_display_selection_new_style.h file:
// select the display class (only one), matching the kind of display panel
#define GxEPD2_DISPLAY_CLASS GxEPD2_BW
// #define GxEPD2_DRIVER_CLASS GxEPD2_750_T7 // GDEW075T7 800x480, EK79655 (GD7965), (WFT0583CZ61)
// SS is usually used for CS. define here for easy change
#ifndef EPD_CS
#define EPD_CS SS
#endif
#if defined(GxEPD2_DISPLAY_CLASS) && defined(GxEPD2_DRIVER_CLASS)
// somehow there should be an easier way to do this
#define GxEPD2_BW_IS_GxEPD2_BW true
#define GxEPD2_3C_IS_GxEPD2_3C true
#define GxEPD2_4C_IS_GxEPD2_4C true
#define GxEPD2_7C_IS_GxEPD2_7C true
#define GxEPD2_1248_IS_GxEPD2_1248 true
#define GxEPD2_1248c_IS_GxEPD2_1248c true
#define IS_GxEPD(c, x) (c##x)
#define IS_GxEPD2_BW(x) IS_GxEPD(GxEPD2_BW_IS_, x)
#define IS_GxEPD2_3C(x) IS_GxEPD(GxEPD2_3C_IS_, x)
#define IS_GxEPD2_4C(x) IS_GxEPD(GxEPD2_4C_IS_, x)
#define IS_GxEPD2_7C(x) IS_GxEPD(GxEPD2_7C_IS_, x)
#define IS_GxEPD2_1248(x) IS_GxEPD(GxEPD2_1248_IS_, x)
#define IS_GxEPD2_1248c(x) IS_GxEPD(GxEPD2_1248c_IS_, x)
#include "GxEPD2_selection_check.h"
#if defined (ESP8266)
#define MAX_DISPLAY_BUFFER_SIZE (81920ul-34000ul-5000ul) // ~34000 base use, change 5000 to your application use
#if IS_GxEPD2_BW(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8) ? EPD::HEIGHT : MAX_DISPLAY_BUFFER_SIZE / (EPD::WIDTH / 8))
#elif IS_GxEPD2_3C(GxEPD2_DISPLAY_CLASS) || IS_GxEPD2_4C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE / 2) / (EPD::WIDTH / 8))
#elif IS_GxEPD2_7C(GxEPD2_DISPLAY_CLASS)
#define MAX_HEIGHT(EPD) (EPD::HEIGHT <= (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2) ? EPD::HEIGHT : (MAX_DISPLAY_BUFFER_SIZE) / (EPD::WIDTH / 2))
#endif
// adapt the constructor parameters to your wiring
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=D8*/ EPD_CS, /*DC=D3*/ 0, /*RST=D4*/ 2, /*BUSY=D2*/ 4));
// mapping of Waveshare e-Paper ESP8266 Driver Board, new version
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=15*/ EPD_CS, /*DC=4*/ 4, /*RST=2*/ 2, /*BUSY=5*/ 5));
// mapping of Waveshare e-Paper ESP8266 Driver Board, old version
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=15*/ EPD_CS, /*DC=4*/ 4, /*RST=5*/ 5, /*BUSY=16*/ 16));
#undef MAX_DISPLAY_BUFFER_SIZE
#undef MAX_HEIGHT
#endif
#if defined(ESP32)
#define MAX_DISPLAY_BUFFER_SIZE 65536ul // e.g.
#endif
#if !IS_GxEPD2_1248(GxEPD2_DRIVER_CLASS) && !IS_GxEPD2_1248c(GxEPD2_DRIVER_CLASS)
#if defined(ARDUINO_LOLIN_D32_PRO)
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 0, /*RST=*/ 2, /*BUSY=*/ 15)); // my LOLIN_D32_PRO proto board
#elif defined(ARDUINO_LOLIN_S2_MINI)
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS*/ 33, /*DC=*/ 35, /*RST=*/ 37, /*BUSY=*/ 39)); // my LOLIN ESP32 S2 mini connection
#else
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // my suggested wiring and proto board
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ 5, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // LILYGO_T5_V2.4.1
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 19, /*RST=*/ 4, /*BUSY=*/ 34)); // LILYGO® TTGO T5 2.66
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=5*/ EPD_CS, /*DC=*/ 2, /*RST=*/ 0, /*BUSY=*/ 4)); // e.g. TTGO T8 ESP32-WROVER
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 15, /*DC=*/ 27, /*RST=*/ 26, /*BUSY=*/ 25)); // Waveshare ESP32 Driver Board
#endif
#else // GxEPD2_1248 or GxEPD2_1248c
// Waveshare 12.48 b/w or b/w/r SPI display board and frame or Good Display 12.48 b/w panel GDEW1248T3 or b/w/r panel GDEY1248Z51
// general constructor for use with all parameters, e.g. for Waveshare ESP32 driver board mounted on connection board
GxEPD2_DISPLAY_CLASS < GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS) > display(GxEPD2_DRIVER_CLASS(/*sck=*/ 13, /*miso=*/ 12, /*mosi=*/ 14,
/*cs_m1=*/ 23, /*cs_s1=*/ 22, /*cs_m2=*/ 16, /*cs_s2=*/ 19,
/*dc1=*/ 25, /*dc2=*/ 17, /*rst1=*/ 33, /*rst2=*/ 5,
/*busy_m1=*/ 32, /*busy_s1=*/ 26, /*busy_m2=*/ 18, /*busy_s2=*/ 4));
#endif
#undef MAX_HEIGHT
#endif
// can't use package "STMF1 Boards (STM32Duino.com)" (Roger Clark) anymore with Adafruit_GFX, use "STM32 Boards (selected from submenu)" (STMicroelectronics)
#if defined(ARDUINO_ARCH_STM32)
#define MAX_DISPLAY_BUFFER_SIZE 15000ul // ~15k is a good compromise
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=PA4*/ EPD_CS, /*DC=*/ PA3, /*RST=*/ PA2, /*BUSY=*/ PA1));
#undef MAX_HEIGHT
#endif
#if defined(__AVR)
#if defined (ARDUINO_AVR_MEGA2560) // Note: SS is on 53 on MEGA
#define MAX_DISPLAY_BUFFER_SIZE 5000 // e.g. full height for 200x200
#else // Note: SS is on 10 on UNO, NANO
#define MAX_DISPLAY_BUFFER_SIZE 800 //
#endif
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
// for Arduino Micro or Arduino Leonardo with CS on 10 on my proto boards (SS would be 17) uncomment instead:
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 10, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#endif
#if defined(ARDUINO_UNOR4_MINIMA) || defined(ARDUINO_UNOR4_WIFI)
#define MAX_DISPLAY_BUFFER_SIZE 16384ul // e.g. half of available RAM
#endif
#endif
#if defined(ARDUINO_ARCH_SAM)
#define MAX_DISPLAY_BUFFER_SIZE 32768ul // e.g., up to 96k
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=10*/ EPD_CS, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7));
#undef MAX_HEIGHT
#endif
#if defined(ARDUINO_ARCH_SAMD)
#endif
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 4, /*DC=*/ 7, /*RST=*/ 6, /*BUSY=*/ 5));
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 4, /*DC=*/ 3, /*RST=*/ 2, /*BUSY=*/ 1)); // my Seed XIOA0
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=4*/ 3, /*DC=*/ 2, /*RST=*/ 1, /*BUSY=*/ 0)); // my other Seed XIOA0
#undef MAX_HEIGHT
#endif
#define MAX_DISPLAY_BUFFER_SIZE 131072ul // e.g. half of available ram
#endif
#if defined(ARDUINO_NANO_RP2040_CONNECT)
#endif
#if defined(ARDUINO_RASPBERRY_PI_PICO)
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 5, /*DC=*/ 8, /*RST=*/ 9, /*BUSY=*/ 7)); // my proto board
// mapping of GoodDisplay DESPI-PICO. NOTE: uses alternate HW SPI pins!
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 3, /*DC=*/ 2, /*RST=*/ 1, /*BUSY=*/ 0)); // DESPI-PICO
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 3, /*DC=*/ 2, /*RST=*/ 11, /*BUSY=*/ 10)); // DESPI-PICO modified
//GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 9, /*DC=*/ 8, /*RST=*/ 12, /*BUSY=*/ 13)); // Waveshare Pico-ePaper-2.9
#endif
#if defined(ARDUINO_RASPBERRY_PI_PICO_W)
#endif
#if defined(ARDUINO_ADAFRUIT_FEATHER_RP2040_THINKINK)
// Adafruit Feather RP2040 ThinkInk used with package https://github.com/earlephilhower/arduino-pico
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ PIN_EPD_CS, /*DC=*/ PIN_EPD_DC, /*RST=*/ PIN_EPD_RESET, /*BUSY=*/ PIN_EPD_BUSY));
#endif
#undef MAX_HEIGHT
#endif
#endif
This is the line you should uncomment.
The code you posted is hardly readable, because of the extra line breaks.
You could also take a look at:
https://github.com/ZinggJM/GxEPD2/blob/master/examples/GxEPD2_WS_ESP32_Driver/GxEPD2_WS_ESP32_Driver.ino
It is pre-configured for the driver board.
That seems to have done the trick!! Thank you!
