Waveshare 7.5in eInk Display doesn't display anything (SKU: 13380)
Hello, I'm pretty new to everything here, so please don't assume I already tried this "obvious" thing.
My Setup:
NMCU-ESP32: ESP32 NodeMCU Development Board - kaufen bei BerryBase
Pinout: https://blog.berrybase.de/wp-content/uploads/2023/11/esp32_abb2.png.webp
Waveshare 7.5in eInk Display (3 colours): Waveshare 13380 7.5inch e-Paper (B), 54,90 €
with HAT Rev2.3: https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT
The hat has 9 pins, which I have connected to the following pins on the ESP32 (first HAT then ESP):
PWR -> not connected
BUSY -> G25
RST -> G26
DC -> G27
CLK -> G15
DIN -> G13
GND -> GND
VCC -> 3.3V
The hat swichtes are set to: 4-line SPI and 0.47R (other options are 3-line SPi and 3R)
I have also tried switching vcc and pwr, and also conncting both to 3.3V.
The ESP seems to run everything just fine, but the display doesn't do anything.
I have tried a different init function (Issue with Waveshare 7.5inch E-Ink Display and ESP32 (no display) - #3 by i_am_trying) with the GxEPD2 library and the test code of the local demo from here: E-Paper ESP32 Driver Board - Waveshare Wiki.
I want to display things on the display. How do I do that?
Thank you for all advice.
Please read the pinned post re 'How to get the most from the forum'.
Could you link it please, I cannot find it.
It is near the top of the topic list of every forum category
Finally fixed it.
First I connected the board to a raspberry pi with the 40 pin connector. The demo worked almost out of the box, so I knew the display wasn't at fault.
Then I went back to the ESP32
|VCC -> 3.3V|
|PWR -> 3.3V| (important, to send a "power on" signal)
|GND -> GND|
|DIN -> G13|
|CLK -> G14|
|CS -> G15|
|DC -> G27|
|RST -> G26|
|BUSY -> G25|
In the Arduino IDE I went to Sketch -> Include Library -> GxEPD2
Then File -> Examples (Scroll to bottom) -> GxEPD2 -> GxEPD2_example
In GxEPD2_Example.ino I added this line at the start of the setup function line ~172 :
SPI.begin(14, -1, 13, 15);
to set my pin layout (-1 means I have no MISO pin).
Then in GxEPD2_display_selection_new_style.h:
around line 20 commented out #define GxEPD2_DISPLAY_CLASS GxEPD2_BW and included #define GxEPD2_DISPLAY_CLASS GxEPD2_3C (was right below the previous)
Also commented in this line (101):
#define GxEPD2_DRIVER_CLASS GxEPD2_750c_Z08 to include the right drivers.
Lastly commented in the following line with the right pins, and commented out the wrong one in that list ~ 221-227
GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 15, /*DC=*/ 27, /*RST=*/ 26, /*BUSY=*/ 25)); // Waveshare ESP32 Driver Board
I'm still unsure why it didn't work before with the standard pins, but since this it's running now, I won't complain.
The Esp32 I used only had one 3.3v pin, so I had to put both pwr and vcc on the same pin.
