Waveshare 7600G-H 4G
My Waveshare 7600G-H 4G Communication Module is hooked up to my Arduino Mega2560 over UART. The TXD on the Waveshare is connected to the 19RX1 on my Arduino and the RXD on the Waveshare is connected to the 18TX1 on my Arduino. I changed all the "Serial.XX" to "Serial1.XX" within the .cpp file library, so the pins on my Arduino should be receiving for that Serial channel. However, the output on my Serial monitor is just returning "AT" every two seconds after it Starts Ups. I'm linking my code and the .cpp file below.
#include <Waveshare_SIM7600.h>
*  @filename   :   SMS.cpp
*  @brief      :   SIM7600CE 4G HAT demo
*  @author     :   Kaloha from Waveshare
*  Copyright (C) Waveshare     April 27 2018
*  http://www.waveshare.com / http://www.waveshare.net
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documnetation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to  whom the Software is
* furished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS OR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
#include "Waveshare_SIM7600.h"
// Pin definition
int POWERKEY = 2;
char phone_number[] = "7038957035";      //********** change it to the phone number you want to call
char text_message[] = "www.plentibytes.com";      //
  Serial1.begin(9600);
  sim7600.PowerOn(POWERKEY);
  printf("Sending Short Message Test:\n");
  sim7600.SendingShortMessage(phone_number,text_message);
  printf("Receiving Short Message Test:\n");
  printf("Please send message to phone %s.\n", phone_number);
  sim7600.ReceivingShortMessage();
*  @filename   :   Waveshare_SIM7600.cpp
*  @brief      :   Implements for sim7600 library
*  http://www.waveshare.com  http://www.waveshare.net
* THE SOFTWARE.
Sim7x00::Sim7x00(){
Sim7x00::~Sim7x00(){
/**************************Power on Sim7x00**************************/
void Sim7x00::PowerOn(int PowerKey = powerkey){
   uint8_t answer = 0;
  // checks if the module is started
  answer = sendATcommand("AT", "OK", 2000);
  if (answer == 0)
    Serial1.print("Starting up...\n");
    pinMode(PowerKey, OUTPUT);
    // power on pulse
    digitalWrite(PowerKey, HIGH);
    digitalWrite(PowerKey, LOW);
    // waits for an answer from the module
    while (answer == 0) {     // Send AT every two seconds and wait for the answer
  delay(5000);
  while ((sendATcommand("AT+CREG?", "+CREG: 0,1", 500) || sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0)
/**************************Phone Calls**************************/
void Sim7x00::PhoneCall(const char* PhoneNumber) {
  char aux_str[30];
//  Serial.print("Enter the phone number:");
//  scanf("%s", PhoneNumber);
  sprintf(aux_str, "ATD%s;", PhoneNumber);
  sendATcommand(aux_str, "OK", 10000);
  // press the button for hang the call
  //while (digitalRead(button) == 1);
  delay(20000);
  Serial1.println("AT+CHUP");            // disconnects the existing call
  Serial1.print("Call disconnected\n");
/**************************SMS sending and receiving message **************************/
//SMS sending short message
bool Sim7x00::SendingShortMessage(const char* PhoneNumber,const char* Message){
  uint8_t answer = 0;
  char aux_string[30];
  Serial1.print("Setting SMS mode...\n");
  sendATcommand("AT+CMGF=1", "OK", 1000);    // sets the SMS mode to text
  Serial1.print("Sending Short Message\n");
  sprintf(aux_string,"AT+CMGS=\"%s\"", PhoneNumber);
  answer = sendATcommand(aux_string, ">", 3000);    // send the SMS number
  if (answer == 1)
      Serial1.println(Message);
      Serial1.write(0x1A);
      answer = sendATcommand("", "OK", 20000);
      if (answer == 1)
          Serial1.print("Sent successfully \n");
          return true;
          Serial1.print("error \n");
          return false;
 //     Serial1.print(answer);
      Serial1.print("error.\n");
      return false;
//SMS receiving short message
bool Sim7x00::ReceivingShortMessage(){
  uint8_t answer = 0;
  int i = 0;
  char RecMessage[200];
  sendATcommand("AT+CPMS=\"SM\",\"SM\",\"SM\"", "OK", 1000);    // selects the memory
    answer = sendATcommand("AT+CMGR=1", "+CMGR:", 2000);    // reads the first SMS
  if (answer == 1)
        answer = 0;
        while(Serial1.available() == 0);
        // this loop reads the data of the SMS
        do{
            // if there are data in the UART input buffer, reads it and checks for the answer
            if(Serial1.available() > 0){
                RecMessage[i] = Serial1.read();
                i++;
                // check if the desired answer (OK) is in the response of the module
                if (strstr(RecMessage, "OK") != NULL)
                    answer = 1;
        }while(answer == 0);    // Waits for the asnwer with time out
 //       RecMessage[i] = '\0';
        Serial1.print(RecMessage);
        Serial1.print("\n");
    return false;
  return true;
/**************************FTP download file to Module EFS , uploading EFS file to FTP**************************/
void Sim7x00::ConfigureFTP(const char* FTPServer,const char* FTPUserName,const char* FTPPassWord){
    char aux_str[50];
    // sets the paremeters for the FTP server
  sendATcommand("AT+CFTPPORT=21", "OK", 2000);
  sendATcommand("AT+CFTPMODE=1", "OK", 2000);
  sendATcommand("AT+CFTPTYPE=A", "OK", 2000);
//  Serial.print(aux_str,"AT+CFTPSERV=\"%s\"", FTPServer);
    sprintf(aux_str,"AT+CFTPSERV=\"%s\"", FTPServer);
    sendATcommand(aux_str, "OK", 2000);
    sprintf(aux_str, "AT+CFTPUN=\"%s\"", FTPUserName);
    sprintf(aux_str, "AT+CFTPPW=\"%s\"", FTPPassWord);
void Sim7x00::UploadToFTP(const char* FileName){
  char aux_str[50];
  Serial.print("Upload file to FTP...\n");
  sprintf(aux_str, "AT+CFTPPUTFILE=\"%s\",0", FileName);
void Sim7x00::DownloadFromFTP(const char* FileName){
  char aux_str[50];
  Serial.print("Download file from FTP...\n");
  sprintf(aux_str, "AT+CFTPGETFILE=\"%s\",0", FileName);
/**************************GPS positoning**************************/
bool Sim7x00::GPSPositioning(){
    uint8_t answer = 0;
    bool RecNull = true;
    int i = 0;
    char LatDD[3],LatMM[10],LogDD[4],LogMM[10],DdMmYy[7] ,UTCTime[7];
    int DayMonthYear;
    float Lat = 0;
    float Log = 0;
    memset(RecMessage, '\0', 200);    // Initialize the string
    memset(LatDD, '\0', 3);    // Initialize the string
    memset(LatMM, '\0', 10);    // Initialize the string
    memset(LogDD, '\0', 4);    // Initialize the string
    memset(LogMM, '\0', 10);    // Initialize the string
    memset(DdMmYy, '\0', 7);    // Initialize the string
    memset(UTCTime, '\0', 7);    // Initialize the string
    Serial.print("Start GPS session...\n");
    sendATcommand("AT+CGPS=1,1", "OK", 1000);    // start GPS session, standalone mode
    delay(2000);
    while(RecNull)
        answer = sendATcommand("AT+CGPSINFO", "+CGPSINFO: ", 1000);    // start GPS session, standalone mode
        if (answer == 1)
            answer = 0;
            while(Serial.available() == 0);
            // this loop reads the data of the GPS
            do{
                // if there are data in the UART input buffer, reads it and checks for the asnwer
                if(Serial.available() > 0){
                    RecMessage[i] = Serial.read();
                    i++;
                        answer = 1;
            Serial.print(RecMessage);
            Serial.print("\n");
            if (strstr(RecMessage, ",,,,,,,,") != NULL)
                i = 0;
                answer = 0;
                RecNull = false;
                sendATcommand("AT+CGPS=0", "OK:", 1000);
            Serial.print("error \n");
            return false;
        delay(2000);
    strncpy(LatDD,RecMessage,2);
    LatDD[2] = '\0';
//    Serial.print("LatDD:");
//    Serial.print(LatDD);
    strncpy(LatMM,RecMessage+2,9);
    LatMM[9] = '\0';
//    Serial.print(" LatMM:");
//    Serial.print(LatMM);
    Lat = atoi(LatDD) + (atof(LatMM)/60);
    if(RecMessage[12] == 'N')
        Serial.print("Latitude is ");
        Serial.print(Lat);
        Serial.print(" N\n");
    else if(RecMessage[12] == 'S')
        Serial.print(Lat);
        Serial.print(" S\n");
        return false;
    strncpy(LogDD,RecMessage+14,3);
    LogDD[3] = '\0';
//    Serial.print("LogDD:");
//    Serial.print(LogDD);
    strncpy(LogMM,RecMessage+17,9);
    LogMM[9] = '\0';
//    Serial.print("LogMM:");
//    Serial.print(LogMM);
    Log = atoi(LogDD) + (atof(LogMM)/60);
    if(RecMessage[27] == 'E')
        Serial.print("Longitude is ");
        Serial.print(Log);
        Serial.print(" E\n");
    else if(RecMessage[27] == 'W')
        Serial.print(Lat);
        Serial.print(" W\n");
        return false;
    strncpy(DdMmYy,RecMessage+29,6);
    DdMmYy[6] = '\0';
    Serial.print("Day Month Year is ");
    Serial.print(DdMmYy);
    Serial.print("\n");
    strncpy(UTCTime,RecMessage+36,6);
    UTCTime[6] = '\0';
    Serial.print("UTC time is ");
    Serial.print(UTCTime);
    Serial.print("\n");
    return true;
/**************************Other functions**************************/
uint8_t Sim7x00::sendATcommand(const char* ATcommand, const char* expected_answer, unsigned int timeout) {
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial.available() != 0){
            response[x] = Serial.read();
//            Serial.print(response[x]);
            x++;
            // check if the desired answer  is in the response of the module
            if (strstr(response, expected_answer) != NULL)
                answer = 1;
    }while((answer == 0) && ((millis() - previous) < timeout));
//    Serial.print("\n");
    return answer;
char Sim7x00::sendATcommand2(const char* ATcommand, const char* expected_answer1, const char* expected_answer2, unsigned int timeout){
    char response[100];
    delay(100);
    x = 0;
    do{
            x++;
            // check if the desired answer 1  is in the response of the module
            if (strstr(response, expected_answer1) != NULL)
                Serial.print("\n");
                answer = 1;
            // check if the desired answer 2 is in the response of the module
            else if (strstr(response, expected_answer2) != NULL)
                Serial.print("\n");
                answer = 2;
    return answer;
Sim7x00 sim7600 = Sim7x00();
