Hey there!
I'm trying hard to get the shield working with anything else than the SoftwareSerial.h library. So fare my best approach was using the NeoSWSerial.h with the following code taken from https://forum.arduino.cc/index.php?topic=468114.0
//#define SIMCOM Serial1 /* direct connection is best */
//#include <AltSoftSerial.h>
//AltSoftSerial SIMCOM; // 8 & 9 is second best
#include <NeoSWSerial.h>
NeoSWSerial SIMCOM( 2, 3 ); // 3rd best..
//SoftwareSerial NOT recommended
#include <NMEAGPS.h>
NMEAGPS gps;
gps_fix fix; // the parsed pieces from the GPRMC
#define DEBUG(x) Serial.println(x)
//#define DEBUG(x) /* to build without any debug prints */
enum state_t
WAITING,
GPS_PWR_ON, GPS_PWR_ON_DELAY,
GPS_PWR_OFF, GPS_PWR_OFF_DELAY,
GPS_PKT_ON, GPS_PKT_ON_DELAY,
GPS_PKT_OFF, GPS_PKT_OFF_DELAY,
GET_GPS, GET_GPS_DELAY
state_t state = WAITING;
uint32_t stateTime;
SIMCOM.begin(9600);
switch (state) {
case WAITING:
serialClear();
if (millis() - stateTime >= 10000) // once every 10 seconds
state = GPS_PWR_ON;
case GPS_PWR_ON:
DEBUG("GPS PWR ON");
SIMCOM.println( F("AT+CGPSPWR=1") );
state = GPS_PWR_ON_DELAY;
stateTime = millis();
case GPS_PWR_ON_DELAY:
serialClear();
if (millis() - stateTime >= 5000)
state = GPS_PKT_ON;
case GPS_PKT_ON:
DEBUG("GPS PKT ON");
SIMCOM.println( F("AT+CGPSOUT=1") );
state = GPS_PKT_ON_DELAY;
case GPS_PKT_ON_DELAY:
serialClear();
if (millis() - stateTime >= 200)
state = GET_GPS;
case GET_GPS:
if (gps.available( SIMCOM )) {
fix = gps.read(); // received a new fix structure!
// You might want to make sure there is valid data from the GPS.
// It may have bad reception, so you need to decide what to do when
// there is no valid data.
// You could stay in this state until the fix becomes valid,
// and then send the message. Your program could get stuck here
// if the GPS reception is bad. Maybe that's what it should do.
// Or you could go ahead and send a message without a lat/lon.
// With the if test commented out, it will send a message now,
// perhaps *without* a valid lat/lon value.
//if (fix.valid.date && fix.valid.time && fix.valid.location) {
// What to do with the GPS data?
Serial.print( fix.dateTime.seconds );
Serial.print( ' ' );
Serial.println( fix.latitude(), 6 );
state = GET_GPS_DELAY;
//} else {
case GET_GPS_DELAY:
serialClear();
state = GPS_PKT_OFF;
case GPS_PKT_OFF:
DEBUG("GPS PKT OFF");
SIMCOM.println( F("AT+CGPSOUT=0") );
state = GPS_PKT_OFF_DELAY;
case GPS_PKT_OFF_DELAY:
serialClear();
state = GPS_PWR_OFF;
case GPS_PWR_OFF:
DEBUG("GPS PWR OFF");
SIMCOM.println( F("AT+CGPSPWR=0") );
state = GPS_PWR_OFF_DELAY;
case GPS_PWR_OFF_DELAY:
serialClear();
if (millis() - stateTime >= 500) {
state = WAITING;
} // loop
void serialClear() {
// Empty the input buffer.
while (SIMCOM.available()) {
char c = SIMCOM.read();
Serial.write( c ); // to see the response, if you want
// while (Serial.available())
// Serial.read();
thanks to -dev https://forum.arduino.cc/index.php?action=profile;u=165590 for the code.
My Output is:
GPS PWR ON
AT+CGPSPWR=1
OK
GPS PKT ON
AT+CGPSOUT=1
OK
Thanks in advance !
Siggi
