Waveshare wm8960 audio board not recognized by Giga I2C
Hi guys ,
It should be a super simple procedure. Connect +3v3, gnd, scl, sda and program the registers.
I did it with the esp32 wroom and the I2C and then the I2S worked perfectly.
However, the GIGA did not recognize the board.
I ran the i2c scanner and it found nothing.
I checked the wires and they are ok. SCL and SDA pins are OK.
I used the oscilloscope and the I2C signals reach the board.
https://www.waveshare.com/wm8960-audio-board.htm
Does anyone know why it is not recognized?
Thank you
Gibran
#include <SPI.h>
#include <Wire.h>
#include <SparkFun_WM8960_Arduino_Library.h>
#include <Arduino_AdvancedAnalog.h>
WM8960 codec;
// WS, CK, SDI, SDO, MCK
AdvancedI2S i2s(PG_10, PG_11, PG_9, PB_5, PC_4);
  while (!Serial)
  delay(1500);
  Serial.println("Codec setup");
  codec_setup();
  if (!i2s.begin(AN_I2S_MODE_INOUT, 96000, 512, 32))
    Serial.println("Failed to start I2S");
    while (1)
    Serial.println("I2S ok");
  if (i2s.available())
    SampleBuffer rxbuf = i2s.read();
    SampleBuffer txbuf = i2s.dequeue();
    for (size_t i = 0; i < rxbuf.size(); i++)
      txbuf[i] = rxbuf[i];
    rxbuf.release();
    i2s.write(txbuf);
    txbuf.release();
void codec_setup()
  Wire.begin();
  if (codec.begin() == false)
    Serial.println("Device not recognized.");
    while (1)
  Serial.println("Codec connected");
  codec.enableVREF();
  codec.enableVMID();
  // DAC
  codec.enableDacLeft();
  codec.enableDacRight();
  codec.disableDacMute();
  codec.enableLD2LO();
  codec.enableRD2RO();
  // ADC
  codec.enableAdcLeft();
  codec.enableAdcRight();
  codec.setAdcLeftDigitalVolumeDB(0.0);
  codec.setAdcRightDigitalVolumeDB(0.0);
  // MIC
  codec.enableLMIC();
  codec.enableRMIC();
  codec.connectLMN1();
  codec.connectRMN1();
  codec.disableLINMUTE();
  codec.disableRINMUTE();
  codec.disableMicBias();
  codec.setLINVOLDB(0);
  codec.setRINVOLDB(0);
  codec.enableAINL();
  codec.enableAINR();
  codec.connectLMIC2B();
  codec.connectRMIC2B();
  codec.setLB2LOVOL(WM8960_OUTPUT_MIXER_GAIN_0DB);
  codec.setRB2ROVOL(WM8960_OUTPUT_MIXER_GAIN_0DB);
  codec.enableLOMIX();
  codec.enableROMIX();
  codec.enableOUT3MIX();
  codec.enableHeadphones();
  codec.setHeadphoneVolumeDB(6.00);
  codec.disableLoopBack();
  codec.enablePeripheralMode();
  codec.setWL(WM8960_WL_16BIT);
Hi Gibran. Which I2C pins are you connecting to? The GIGA has 3 x I2C.
Hi Steve ,
pins 20 and 21.
Do you have the wm8960 VIN connected to the GIGA 5v?
the board has VCC, but it doesn't say if it's 3v3 or 5v. I used it connected to the 3v3 of the ESP32 and it worked, so I repeated the same on the giga. I used i 3v3
My mistake, I was looking at the sparkfun board as you are using their library. The VIN spec for your board is 3.3v.
Steve , I forgot too , there is an schematic of the board.
I modified the original board to add a "line in" connector to replace the original MIC.
Found the problem:
I opened the Sparkfun Library and commented the "sensor" lines !!!
It is alive!!!!!!
Thanks
boolean WM8960::begin(TwoWire &wirePort)
  	_i2cPort = &wirePort;
  	// if (isConnected() == false) // Check for sensor by verifying ACK response
    // 	return (false);
    if (reset() == false) // Reset all registers to default values
      return (false);
  	return (true); //We're all setup!
Good to hear
