I have a DS1302 RTC board (Waveshare) connected to an Arduino uno.
I’m printing time to Arduino’s Serial Monitor but I get weird numbers/characters, and after 2-4 seconds it stops printing.
Wiring:
Vcc → 5v
GND → GND
I/O (MISO) → Pin 12
SCLK → Pin 13
CE (CS) → Pin 10
Library used: VirtuabotixRTC library.
Things I’ve tried so far:
I tried a second DS1302 RTC board.
I tried a different Arduino board.
I tried changing the jumper wires.
I tried different baud rates.
I recently saw a youtube tutorial which had the same issue and solved it with a series 1k resistor between I/O pin and Arduino’s input pin. I did the same, I tested different resistor values but I still have the problem.
Code:
#include <virtuabotixRTC.h>
virtuabotixRTC myRTC(7,8,9);
// myRTC.setDS1302Time(30,30,5,5,5,5,2020);
myRTC.updateTime();
Serial.print(myRTC.hours);
Serial.print(":");
Serial.print(myRTC.minutes);
Serial.print(":");
Serial.println(myRTC.seconds);
I’m fairly convinced it has to do with the I/O pin resistor (or other DS1302 pin), but I haven’t managed to solve it. Any insight welcomed.
