WaveShield + Led Matrix query.
Hello world,
First time post but I have referenced this forum a lot for help on my arduino project. I am building a clock that involves two 'Sure electronics 16x24 green led displays" and a ladyada wave shield. http://www.ladyada.net/make/waveshield/
The Led matrix displays the time and the wave shield plays a wake up .wav file when the alarm goes off.
I have been working on them separately and trying to now combine them. I had the wav shield successfully playing one of the sample files off the website that loops all .wav files on sd card. Once I combined the led display to go off of the pins from the wav shield the speaker decided to sop working. The led display still worked fine. I even took all of the wires connecting to the display and still I hear only static when running the exact program that worked earlier today.
This just stumpts me. Any advice is greatly appreciated. I am fairly new to arduino so I may be missing something simple.
Thanks in advance, everything is hugely appreciated.
There are two possibilities.
One is that there is a wiring problem. Whether or not that is the case can not be determined, since you posted no schematic.
The other is that it is a software problem. Again, whether or not that is the case can not be determined, since you posted no code.
I do believe the ball is back in your court.
You probably ran out of memory (RAM) on Arduino. Try doing the same thing using a bigger ATmega, like the one in Arduino Mega or Sanguino (or my own Duino644, for that matter).
