wavgat problems...
Lot of thanks for wireis.
His solution solved my problem.
Best regards.
Bernard.
Another problem is that the analogRead function behave abnormally.
It can work but:
ADC is 12bit. Readings make sens (in my case) only when I give it as AREF 3.3V (pin 3v3) and ad some code:
void setADC(){
  analogReference(EXTERNAL);
  analogReadResolution(12);
And read with
setADC();
analogRead(A0);
Score in range 0-4064 (why? i don't know).
If you use something using I2C then analogRead will not work on pin A5 and A4
Seems GPIO work at 3.3V (instead of 5V)
(Voltages not checked with multimeter yet!)
Multimeter show 3.01V in HIGH and -0.21V in LOW
Hope it help someone
Thanks Arthur310
Updated [WAVGAT pseudo-clone] Issues and Troubleshouting
Please, if possible could you also check voltage of GPIO (Digital outputs and inputs)?
We suspect it could also be 3.3V instead of 5V.
Also, just for confirmation, with your code would it be possible to make WAVGAT behave as a regular UNO?
void setADC(){
  analogReference(EXTERNAL); // Feeding AREF with 5V
  analogReadResolution(8);
Hi.
This is actually repeating what joemon posted earlier, using other words.
I spent several hours trying to program a wavgat. Following the instructions in this thread. Nothing worked.
Then I changed to another wavgat, and everything worked like charm first time.
An important observation is that the faulty wavgat did not lit up the yellow led "L" beside the red led, when connecting the usb-cable. The working wavgat flickered the yellow led when connecting the cable.
So that is a way of identifying a faulty wavgat. Hope that saves time for someone else...
BR / Mats
AingeruJM:
It’s 3,3V
AingeruJM:
void setADC(){
No feeding AREF with 5V give some wrong score.
It looks like here you have lot’s of answers:
http://www.ocrobot.com/doku.php?id=ocrobot:alpha:8f328p-u:main
This is it. ADC give 4064 as max score. Like there. Without feedeng AREF it works with ref 1.024\2.048\4.096 internal.
System logic level: Factory 5V (can be switched to 3V3 through the pad) but here looks like it’s factory 3,3V. How to switch it? I do not know. I am new to arduino. It’s my first board so I’m learning on this “thing”.
bookaroo give link: GitHub - LGTMCU/Larduino_HSP: Hardware support package for Larduino
this work but if I use this driver LCD I2C does not work properly (LiquidCrystal_I2C.h). Someone know how to fix it? It looks like this driver is better (no errors). If i use
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
  lcd.init();                      // initialize the lcd
  // Print a message to the LCD.
  lcd.backlight();
  lcd.clear();
  lcd.print("Hello, world!");
  lcd.print("ello, world!");
  lcd.print("ArduinoSolutions.com");
on screen I can see only “HeA”. always only first letter.
EDIT
Update LiquidCrystal_I2C to 1.1.2 and it work OK
In both driver there is no way to use EEPROM.h. After reset read ‘0’ whatever write. But how long its work it give proper readings of what you write.So it looks like there is some kind of emulation of EEPROM only. Or I do not know how to use it. Any ideas?
EDIT
The EEPROM library found on one of the Russian-language websites has been helped here. I do not have any guys from where I downloaded it unfortunately. Because I made a mess in the libraries, I changed its name to EEPROM1.h. Work with those drivers GitHub - LGTMCU/Larduino_HSP: Hardware support package for Larduino
I did not try with those from seller.
It’s only basic but better than nothing. Example:
#include <EEPROM1.h>
void setup(){
void loop(){
 Serial.print(EEPROM.read(1));
 Serial.print(" - ");
 Serial.print(EEPROM.read(10));
 Serial.println(EEPROM.read(100));
 delay(2500);
 if(Serial.read()=='0'){
  EEPROM.write(1, 10);
  EEPROM.write(10, 03);
  EEPROM.write(100, 90);
  Serial.println("update done");
@Mats_Lind
mine does. yellow led bling some time when conecting the cable.
E2PROM1.zip (5.97 KB)
I also bought me a few of those cheap Wavgat Uno boards knowing the risk I was taking. But for only $ 5 for the two including shipment I was ready to take the risk. And yes as expected it didn’t work when I connected it as an Arduino Uno. But when you read the backside of the board, there is a loud and clear text that says you have to connect it as a Wavgat Uno 3 in the software. Meaning you have to download the board from somewhere. And as Wireis clearly pointed out in his posting at page one of this thread you can download the correct files here https://drive.google.com/open?id=10gwrG9uTDwaEO-7EudsmBkfgdcyrcABI . I did that and pasted the correct files into the Arduino directory's and restarted the Arduino IDE and uploaded a sketch. And voila its working well. The CH340 issue may not be a problem anymore, that may be a well know issue now a days.
The only additional thing I have to say to the pasting of the files is that you must be careful not to just paste the Hardware and Library directory if there are already files in there. Only paste the files inside the downloaded Hardware and Library folder to the Arduino Hardware and Library directory’s, don’t overwrite your existing ones.
By the way, the information Wireis posted is also mentioned on the webpage of the Aliexpress seller. https://nl.aliexpress.com/item/WAVGAT-hoge-kwaliteit-Een-set-UNO-R3-CH340G-MEGA328P-voor-Arduino-UNO-R3-USB-KABEL-ATMEGA328P/32877460592.html?spm=a2g0s.9042311.0.0.27424c4dVDUhoa So there has not to be any problem. Just good reading ..... :wink:
took hours to find this fix, thank you
Hello,
Just wondering if anyone more news or fixes , tips or links about the wavgat uno r3 boards? (they are not clones since they are definatly not 100% compatible)
I have 3 of those and I rather like the fact they have a 12 bit analog read resolution. The 10 bit of the regular arduino is rather crude. Specially if you use it with those bi directional current sensors. Than you only have 512 steps to devide 30 amps. (yes I will get a 20amps version) But of course I cannot read the analog values since the wavgat maxes at 3.3 volt. Also plenty of problems with a lot of libraries to get displays and other things working.
So I have them laying arround now and use nano clones which is great fun too but I rather use the wavgat since it is (suposedly) more precise and it feels like a shame to do nothing with them.
Regards,
Hans.
You would want to talk to wavgat or thier forum.
These have to be about the worst copy of an arduino available with too many issues to list.
Also posting into old threads is frowned on.
Could you take a few moments to Learn How To Use The Forum.
Bob.
