WAYS OF COMMUNICATION
I´m new in this beautiful of programming. I have 2 arduinos and I want to communicate each other.
What ways do I have to do this? and, What information can I send????? Obviously wired...
On the other hand, I want to know what´s the utility of having 2 or more windows in an arduino program
Is it only to see it better??? Or has it an utility?
you can communicate via serial, SPI, or I2C. the information you can send is the information you gather or generate in the programs you write
Telmooo:
Anything you want.
I don't know what you have in mind when you refer to "windows in an arduino program". In my mind "windows" are PC concept.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
If you are using Unos it would be a good idea to use SoftwareSerial for communication with the other Arduino so as to leave HardwareSerial (pins 0 and 1) free for uploading code and for debug messages to the Arduino Serial Monitor.
...R
