Ways to make my code short or efficient?
I’ve done a switching digits and increment it by 1, is there any other way to make my code shorter. The code works fine but I want it to be efficient is there any other way?
const byte segment_a = 11;
const byte segment_b = 12;
const byte segment_c = 13;
const byte segment_d = 14;
const byte segment_e = 15;
const byte segment_f = 16;
const byte segment_g = 17;
const byte segment_dp = 18;
const byte digit1 = 10;
const byte digit2 = 8;
const byte digit3 = 7;
int b1, b2;
int inc1 = 0;
int inc2 = 0;
  pinMode(segment_a, OUTPUT);
  pinMode(segment_b, OUTPUT);
  pinMode(segment_c, OUTPUT);
  pinMode(segment_d, OUTPUT);
  pinMode(segment_e, OUTPUT);
  pinMode(segment_f, OUTPUT);
  pinMode(segment_g, OUTPUT);
  pinMode(segment_dp, OUTPUT);
  pinMode(digit1, OUTPUT);
  pinMode(digit2, OUTPUT);
  pinMode(digit3, OUTPUT);
  b1 = digitalRead(2);
  if (b1 == HIGH) {
  inc1++;
  btn1(inc1);
    if(inc1 > 2) {
     inc1 = 0;
  b2 = digitalRead(3);
  if (b2 == HIGH) {
  inc2++;
  btn2(inc2);
    if(inc2 == 10) {
     inc2 = 0;
void btn1(int x)
  if(x == 1) {
    clearAll();
    inc2 = 0;
    digitalWrite(digit1, OUTPUT);
    digitalWrite(segment_a, LOW);
    digitalWrite(segment_b, LOW);
    digitalWrite(segment_c, LOW);
    digitalWrite(segment_d, LOW);
    digitalWrite(segment_e, LOW);
    digitalWrite(segment_f, LOW);
    digitalWrite(segment_g, LOW);
    digitalWrite(segment_dp, HIGH);
  if(x == 2)
    clearAll();
    inc2 = 0;
    digitalWrite(digit2, OUTPUT);
  if(x == 3)
    clearAll();
    inc2 = 0;
    digitalWrite(digit3, OUTPUT);
void btn2(int x)
  if (x == 1)
    digitalWrite(inc1, HIGH);
    digitalWrite(segment_b, HIGH);
    digitalWrite(segment_c, HIGH);
  if (x == 2)
    digitalWrite(segment_a, HIGH);
    digitalWrite(segment_d, HIGH);
    digitalWrite(segment_e, HIGH);
    digitalWrite(segment_g, HIGH);
  if (x == 3)
  if (x == 4)
    digitalWrite(segment_f, HIGH);
  if (x == 5)
  if (x == 6)
  if (x == 7)
  if (x == 8)
    digitalWrite(segment_dp, HIGH);;
  if (x == 9)
  if (x == 10)
void clearAll()
  digitalWrite(digit1, LOW);
  digitalWrite(digit2, LOW);
  digitalWrite(digit3, LOW);
  digitalWrite(segment_dp, LOW);
Sure. You can give functions meaningful names. The Arduino team chose digitalRead(), for instance, not D77444(). Only you can guess what btn1() is doing.
In those functions, you have a series of if statements, a maximum of which one can be true. Use else ifs or a switch statement.
Do not have the same code in all of the bodies/cases. There is no need to call clearAll() if x is 1 or if x is 2 or if x is 3. Just call clearAll().
There is very little difference between showing a 3 in position 1 or position 2 or position 3. You should have one function that can display a number in a position.
void showDigit(byte val, byte pos)
   // Some code
    showDigit(3, 0);
    showDigit(7, 1);
    showDigit(8, 2);
The second argument to digitalWrite() is NEVER OUTPUT.
this is a start but you could use a function to handle all digits and pas simple byte numbers to control all digits
  if (x == 10)
    Segment(B10111111,B0,B1);
    /* replaces:
void clearAll()
  Segment(B0,B0,B0);
 void Segment(byte Seg, byte digit,byte inc1){
  digitalWrite(inc1, inc1);
  digitalWrite(digit1, bitRead(digit, 1));
  digitalWrite(digit2, bitRead(digit, 2));
  digitalWrite(digit3, bitRead(digit, 3));
  digitalWrite(segment_a, bitRead(Seg, 0));
  digitalWrite(segment_b, bitRead(Seg, 1));
  digitalWrite(segment_c, bitRead(Seg, 2));
  digitalWrite(segment_d, bitRead(Seg, 3));
  digitalWrite(segment_e, bitRead(Seg, 4));
  digitalWrite(segment_f, bitRead(Seg, 5));
  digitalWrite(segment_g, bitRead(Seg, 6));
  digitalWrite(segment_dp, bitRead(Seg, 7));
Z
