Wdt reset . help me please to fix
after send sms "get" to Program:
it 's show on serial monitor
wdt reset
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00044e70
~ld
..........................code program.................
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
const String PHONE_NUMBER = "+66935474953";
// Define RX/TX pins for GSM Module
#define GSM_RX_PIN D5
#define GSM_TX_PIN D6
SoftwareSerial sim800(GSM_RX_PIN, GSM_TX_PIN);
// Define RX/TX pins for GPS Module
#define GPS_RX_PIN D7
#define GPS_TX_PIN D8
SoftwareSerial neogps(GPS_RX_PIN, GPS_TX_PIN);
TinyGPSPlus gps;
String receivedCommand = "";
Serial.println("Start of setup");
Serial.println("Arduino serial initialize");
sim800.begin(9600);
Serial.println("SIM800L serial initialize");
neogps.begin(9600);
Serial.println("GPS serial initialize");
sim800.listen();
neogps.listen();
sim800.println("AT+CMGF=1\r"); // Set SMS mode to text
Serial.println("Setup complete.");
Serial.println("End of setup");
ESP.wdtFeed(); // āļŦāļĢāļ·āļ­ ESP8266.wdtFeed()
while (sim800.available()) {
parseSMS(sim800.readString());
// āļĢāļ­āļĢāļąāļšāļ„āļģāļŠāļąāđˆāļ‡āļˆāļēāļāļœāļđāđ‰āđƒāļŠāđ‰
if (receivedCommand == "get") {
checkGPSCommand();
// āļĢāļĩāđ€āļ‹āđ‡āļ•āļ„āļģāļŠāļąāđˆāļ‡āļ—āļĩāđˆāđ„āļ”āđ‰āļĢāļąāļš
//delay(1000); // āļžāļąāļāđ€āļžāļ·āđˆāļ­āļ›āđ‰āļ­āļ‡āļāļąāļ™āļāļēāļĢāļ—āļģāļ‡āļēāļ™āđāļšāļšāđ„āļĄāđˆāļˆāļš
void parseSMS(String sms) {
Serial.println("Received SMS: " + sms); // Display the received SMS in Serial Monitor
sms.trim();
if (sms.startsWith("+CMTI")) {
int index = sms.indexOf(",");
String temp = sms.substring(index + 1);
temp.trim();
temp = "AT+CMGR=" + temp + "\r";
sim800.println(temp);
} else if (sms.startsWith("+CMGR")) {
extractSMS(sms);
void extractSMS(String sms) {
String senderNumber = sms.substring(index + 2, index + 15);
senderNumber.trim();
index = sms.indexOf("\n");
String message = sms.substring(index + 1);
message.trim();
Serial.println("Sender Number: " + senderNumber);
Serial.println("Message: " + message);
if (senderNumber == PHONE_NUMBER) {
processCommand(message);
void processCommand(String command) {
// āđƒāļŦāđ‰āļ—āļģāļāļēāļĢ trim() āļāđˆāļ­āļ™āđ€āļ›āļĢāļĩāļĒāļšāđ€āļ—āļĩāļĒāļš
command.trim();
if (command.equalsIgnoreCase("get")) {
receivedCommand = command;
Serial.println("Received command: " + receivedCommand);
void checkGPSCommand() {
Serial.println("Checking GPS Command");
// āļ•āļĢāļ§āļˆāļŠāļ­āļšāļ§āđˆāļēāļĄāļĩāļ„āļģāļŠāļąāđˆāļ‡ "get" āļ–āļđāļāļŠāđˆāļ‡āļĄāļēāļŦāļĢāļ·āļ­āđ„āļĄāđˆ
// āļ•āļĢāļ§āļˆāļŠāļ­āļš GPS Data āđāļĨāļ°āļŠāđˆāļ‡ SMS āļ—āļĩāđˆāļĄāļĩāļ‚āđ‰āļ­āļĄāļđāļĨāļ•āļģāđāļŦāļ™āđˆāļ‡ GPS
while (neogps.available()) {
  if (gps.encode(neogps.read())) {
    if (gps.location.isValid()) {
      Serial.println("Sending Location SMS");
      sendLocationSMS();
      Serial.println("Invalid GPS Location");
    Serial.println("GPS Data Not Received");
void sendLocationSMS() {
Serial.print("Sending Location SMS...");
sim800.print("AT+CMGS="" + PHONE_NUMBER + ""\r");
sim800.print("Google Maps");
sim800.print(gps.location.lat(), 6);
sim800.print(",");
sim800.print(gps.location.lng(), 6);
sim800.write(0x1A); // āđ„āļĄāđˆāļ•āđ‰āļ­āļ‡āđƒāļŠāđ‰ delay āļŦāļĨāļąāļ‡āļˆāļēāļāļāļēāļĢāļŠāđˆāļ‡āļ‚āđ‰āļ­āļĄāļđāļĨ
unsigned long startMillis = millis();
while (millis() - startMillis < 10000) { // āļĢāļ­āļāļēāļĢāļ•āļ­āļšāļāļĨāļąāļšāļˆāļēāļāđ‚āļĄāļ”āļđāļĨ GSM āļ āļēāļĒāđƒāļ™ 10 āļ§āļīāļ™āļēāļ—āļĩ
if (sim800.available()) {
String response = sim800.readString();
Serial.println("Response from GSM module: " + response);
Serial.println("GPS Location SMS Sent Successfully.");
Serial.println("Invalid GPS data");
Hi @kruwanchai ,
Welcome to the forum..
try feeding the watchdog in this loop inside sendLocationSMS..
good luck.. ~q
How?
sim800.print(",");
    // Feed the watchdog here
same way you do at the start of your loop()..
it's the first command, looks like you were using ESP8266 then upgraded to ESP32..
~q
    ESP.wdtFeed();
No wdt reset, but still haven't received sms reply.
(void sendLocationSMS() )
good news,
you are looping for 10 seconds waiting for that reply, this is what i figured causes the dog to bark..
now figure out why no response..
do you still have the feed in the "if" or is it like i posted??
~q
All function...
sim800.print(",");
    ESP.wdtFeed();
try..
sim800.print(",");
    ESP.wdtFeed(); //feed dog
    yieldIfNecessary();//allow other tasks
no function yieldIfNecessary in the Arduino Core library for ESP8266. Right?
I use yield();
yield();//allow other tasks
Haven't received a reply to SMS yet.
do you receive the sms??
~q
No sir.
I have this program code that can send SMS as a link or Google Maps, but it sends automatically and in a loop. So I adjusted it to wait to receive the "get" command from the "PHONE_NUMBER" The results showed that there was an error as posted above.
///code program///
const String PHONE_NUMBER = "+66935xxxxxx";
TinyGPSPlus gps;
sim800.begin(9600);
neogps.begin(9600);
sim800.listen();
neogps.listen();
checkGPSCommand();
sms.trim();
temp.trim();
extractSMS(sms);
message.trim();
if (message == "get location") {
sendLocationSMS();
sendLocationSMS();
sim800.print(",");
delay(100);
sim800.write(0x1A);
once more try..
Serial.println("entering: sendLocationSMS...");
  Serial.println("location is valid");
sim800.print("AT+CMGS=\"" + PHONE_NUMBER + "\"\r");
sim800.print(",");
sim800.println((char)26);
//sim800.write(0x1A); // āđ„āļĄāđˆāļ•āđ‰āļ­āļ‡āđƒāļŠāđ‰ delay āļŦāļĨāļąāļ‡āļˆāļēāļāļāļēāļĢāļŠāđˆāļ‡āļ‚āđ‰āļ­āļĄāļđāļĨ
bool timedOut = true;
    Serial.println("Response available..");
    timedOut = false;
if (!timedOut){
Serial.println("GPS Location SMS Sent Successfully."); } else
Serial.println("Response timed out..");
pretty sure it was the dialing string was bad..
good luck.. ~q
when you post code hit that little code button and paste it in..
i would have caught the coloring, it would have helped..
try this..
Serial.print("AT+CMGS="" + PHONE_NUMBER + ""\r");
you'll see what i mean..
happy holidays.. ~q
Thank you.
///update code///
TinyGPSPlus gps;
Serial.println("Checking Network Registration...");
sim800.println("AT+CREG?");
sim800.begin(9600);
neogps.begin(9600);
sim800.listen();
neogps.listen();
Serial.write(sim800.read());
checkGPSCommand();
sms.trim();
temp.trim();
sim800.flush();
extractSMS(sms);
message.trim();
command.trim();
      sendLocationSMS();
  ESP.wdtFeed();
sim800.print(",");
timedOut = false;
if (!timedOut){
