WDT reset problem - ESP8266MOD
I am new to the Arduino. I am facing a strange WDT reset problem while enabling a pin as an input.
I have connected a switch into pins GPIO12 and GPIO13. If I added the following line in my program its getting reset.
pinMode(6, INPUT);
wdt reset
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
Selected board as -> Node MCU 1.0 (esp12E)
Kindly help me to solve this issue.
Thanks.
How? What makes you think that there is a relationship between either of these two names and the numeric value 6?
And what do you plan to do with that pin, read a button ? do you use a loop ? ESP wdt reboots the board if it hasn't been reset after 2.5ms, either a delay() or a yield() resets the wdt or the end of void loop() (which incurs an automatic yield() and then restarts loop() )
Thanks For the reply. Here I attached my test code.
I had connected two switches in GPIO12 (Pin no 6) and GPIO13 (pin no 7). Its normally pull up.
If I configured the pins as input then I am getting WDT to reset in the serial monitor. If I removed these lines I won't get reset message but the switch input was not working.
pinMode(buttonPin, INPUT);
pinMode(buttonPin1, INPUT);
How to relate the GPIO number and pin number in code?
Define the GPIO or pin number?
const int buttonPin = 6; // the number of the pushbutton pin GPIO12
const int buttonPin1 = 7; // the number of the pushbutton pin GPIO13
int TestPin = 20;
int Relayout1 = 19;//GPIO4
int Relayout2 = 20;//GPIO5
int Relayout3 = 11;//GPIO9
int reading =0 , BounceReading = 0;
/*Function declarations --- */
void ScanKeys (void);
Serial.println("Code Started.. \n");
//Init Button pin mode
ScanKeys();
reading = digitalRead(buttonPin); //gpio12
if (reading == HIGH)
Serial.println("High \n");
Serial.println("Low \n");
Define the GPIO nr, don’t bother about the pinnr. The GPIO nr is what the compiler translates to pinnrs for you.
I have modified the definition like below, but still, my board getting reset :frowning:
const int buttonPin = 12; // the number of the pushbutton pin GPIO12
const int buttonPin1 = 13; // the number of the pushbutton pin GPIO13
