HI guys...
I am trying to load a bitmap image on Weact 1.54" epaper display.
I found a sample for text..but I don't find any for bitmap
So I tryed to edit this: but I receive this error
Compilation error: no matching function for call to 'drawGrayscaleBitmap(const unsigned char [5000], int, int, int16_t, int16_t, int)'
Where can I find a code sample?
// base class GxEPD2_GFX can be used to pass references or pointers to the display instance as parameter, uses ~1.2k more code
// enable or disable GxEPD2_GFX base class
#define ENABLE_GxEPD2_GFX 0
#include "image.h"
#include <GxEPD2_BW.h>
#include <GxEPD2_3C.h>
#include <Fonts/FreeMonoBold9pt7b.h>
// ESP32 CS(SS)=5,SCL(SCK)=18,SDA(MOSI)=23,BUSY=15,RES(RST)=2,DC=0
// 1.54'' EPD Module
GxEPD2_BW<GxEPD2_154_D67, GxEPD2_154_D67::HEIGHT> display(GxEPD2_154_D67(/*CS=5*/ 5, /*DC=*/ 0, /*RES=*/ 2, /*BUSY=*/ 15)); // GDEH0154D67 200x200, SSD1681
// 2.13'' EPD Module
//GxEPD2_BW<GxEPD2_213_BN, GxEPD2_213_BN::HEIGHT> display(GxEPD2_213_BN(/*CS=5*/ 5, /*DC=*/ 0, /*RES=*/ 2, /*BUSY=*/ 15)); // DEPG0213BN 122x250, SSD1680
//GxEPD2_3C<GxEPD2_213_Z98c, GxEPD2_213_Z98c::HEIGHT> display(GxEPD2_213_Z98c(/*CS=5*/ 5, /*DC=*/ 0, /*RES=*/ 2, /*BUSY=*/ 15)); // GDEY0213Z98 122x250, SSD1680
// 2.9'' EPD Module
//GxEPD2_BW<GxEPD2_290_BS, GxEPD2_290_BS::HEIGHT> display(GxEPD2_290_BS(/*CS=5*/ 5, /*DC=*/ 0, /*RES=*/ 2, /*BUSY=*/ 15)); // DEPG0290BS 128x296, SSD1680
//GxEPD2_3C<GxEPD2_290_C90c, GxEPD2_290_C90c::HEIGHT> display(GxEPD2_290_C90c(/*CS=5*/ 5, /*DC=*/ 0, /*RES=*/ 2, /*BUSY=*/ 15)); // GDEM029C90 128x296, SSD1680
display.init(115200,true,50,false);
helloWorld();
helloFullScreenPartialMode();
if (display.epd2.hasFastPartialUpdate)
showPartialUpdate();
display.hibernate();
const char HelloWorld[] = "xxxxxx!";
const char HelloWeACtStudio[] = "xxxxxxxxxxxx";
void helloWorld()
display.setRotation(1);
display.setFont(&FreeMonoBold9pt7b);
display.setTextColor(GxEPD_BLACK);
int16_t tbx, tby; uint16_t tbw, tbh;
display.getTextBounds(HelloWorld, 0, 0, &tbx, &tby, &tbw, &tbh);
// center the bounding box by transposition of the origin:
uint16_t x = ((display.width() - tbw) / 2) - tbx;
uint16_t y = ((display.height() - tbh) / 2) - tby;
display.setFullWindow();
display.firstPage();
do
display.fillScreen(GxEPD_WHITE);
display.setCursor(x, y-tbh);
display.print(HelloWorld);
display.setTextColor(display.epd2.hasColor ? GxEPD_RED : GxEPD_BLACK);
display.getTextBounds(HelloWeACtStudio, 0, 0, &tbx, &tby, &tbw, &tbh);
display.setCursor(x, y+tbh);
display.print(HelloWeACtStudio);
while (display.nextPage());
void helloFullScreenPartialMode()
//Serial.println("helloFullScreenPartialMode");
const char fullscreen[] = "full screen update";
const char fpm[] = "fast partial mode";
const char spm[] = "slow partial mode";
const char npm[] = "no partial mode";
display.setPartialWindow(0, 0, display.width(), display.height());
if (display.epd2.WIDTH < 104) display.setFont(0);
const char* updatemode;
updatemode = fpm;
else if (display.epd2.hasPartialUpdate)
updatemode = spm;
updatemode = npm;
// do this outside of the loop
// center update text
display.getTextBounds(fullscreen, 0, 0, &tbx, &tby, &tbw, &tbh);
uint16_t utx = ((display.width() - tbw) / 2) - tbx;
uint16_t uty = ((display.height() / 4) - tbh / 2) - tby;
// center update mode
display.getTextBounds(updatemode, 0, 0, &tbx, &tby, &tbw, &tbh);
uint16_t umx = ((display.width() - tbw) / 2) - tbx;
uint16_t umy = ((display.height() * 3 / 4) - tbh / 2) - tby;
// center HelloWorld
uint16_t hwx = ((display.width() - tbw) / 2) - tbx;
uint16_t hwy = ((display.height() - tbh) / 2) - tby;
do
display.setCursor(hwx, hwy);
display.setCursor(utx, uty);
display.print(fullscreen);
display.setCursor(umx, umy);
display.print(updatemode);
//Serial.println("helloFullScreenPartialMode done");
void showPartialUpdate()
// some useful background
helloWorld();
// use asymmetric values for test
uint16_t box_x = 10;
uint16_t box_y = 15;
uint16_t box_w = 70;
uint16_t box_h = 20;
uint16_t cursor_y = box_y + box_h - 6;
if (display.epd2.WIDTH < 104) cursor_y = box_y + 6;
float value = 13.95;
uint16_t incr = display.epd2.hasFastPartialUpdate ? 1 : 3;
// show where the update box is
for (uint16_t r = 0; r < 4; r++)
display.setRotation(r);
display.setPartialWindow(box_x, box_y, box_w, box_h);
do
display.fillRect(box_x, box_y, box_w, box_h, GxEPD_BLACK);
//display.fillScreen(GxEPD_BLACK);
delay(2000);
do
display.fillRect(box_x, box_y, box_w, box_h, GxEPD_WHITE);
//return;
// show updates in the update box
for (uint16_t i = 1; i <= 10; i += incr)
do
display.setCursor(box_x, cursor_y);
display.print(value * i, 2);
do
//display.drawExampleBitmap(gImage_quote, 0, 0, GxEPD_WIDTH,GxEPD_HEIGHT, GxEPD_BLACK);
display.drawGrayscaleBitmap(gImage_IMAGE, 0, 0, display.width(), display.height(), GxEPD_BLACK)
display.update();
delay(10000);
