Weakness on "Language Comparison" Page
The Arduino/Processing Language Comparison page (http://www.arduino.cc/en/Reference/Comparison) suggests that in making an Arduino loop we must use this syntax:
int i;
for (i = 0; i < 5; i++) { … }
as compared to Processing, which embeds the index variable declaration within the loop definition:
for (int i = 0; i < 5; i++) { … }
This distinction is not strictly correct, as either usage is perfectly valid in Arduino (and C++). I think both are valid in Java as well, and probably in Processing too. This section is misleading and should probably be removed.
mh
Quite right.
And there are some differences that may be worth mentioning, such as : * The size of the data types is different, so for example integer code that works in processing may overflow on the arduino * Java has no preprocessor, so Arduino code using #defines (or macros) need to be re-coded * Creation of types using 'new' is not supported on the arduino (it is in C++ but not the version used by the Arduino)
