Thanks in advance for those who are able provide guidance and to educate me on my issue.
Some background on what I’m trying to accomplish. I’m building a sketch that displays the weather forecast using ambient design. Information is pulled from a PHP script that builds a page that displays a unique character indicating the weather forecast (S=Same C=Cold W=Warm). The LEDs display the forecast temperature and any precipitation.
Using the TwitterClient ethernet example, I’ve been able to retrieve the data from my site and turn on the correct LED. In the process of building this sketch I’ve also learned the difference between delay() and millis(), which is where I’m stumbling now. In the example sketch below, I’d like the LEDs (for now) to blink if the forecast matches, which does not occur and the LED simply turns on. My understanding is that the Arduino is running through the loop very quickly and I’m certain my blink timer is not able to run fully because of this. Ideally the LED should blink in the duration between server calls. My hunch is that the blink timer does initiate, but it’s too quick to fully run before readingforecast = false
Using Uno with ethernet shield.
Looking forward to your responses.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char serverName[] = "lessismorecast.com";
EthernetClient client;
const int whitePin = 9;
const int redPin = 6;
const int bluePin = 5;
const unsigned long requestInterval = 30000; // delay between requests
unsigned long lastAttemptTime = 0; // last time connected to the server
unsigned long currentTime;
unsigned long loopTime;
String currentLine = ""; // string to hold the text from server
String forecast = ""; // string to hold the forecast
boolean readingforecast = false; // if you're currently reading the forecast
boolean requested; // whether you've made a request since connecting
pinMode(whitePin, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(bluePin, OUTPUT);
currentTime = millis();
loopTime = currentTime;
currentLine.reserve(256); // reserve space for the strings
forecast.reserve(150); // reserve space for forecast strings
// Start up the ethernet shield
if (Ethernet.begin(mac) == 0) { // start ethernet using mac & IP address
Serial.println("Failed to configure Ethernet using DHCP");
while(true); // no point in carrying on, so stay in endless loop
connectToServer();
if (client.connected()) {
if (client.available()) { // read incoming bytes
char inChar = client.read();
currentLine += inChar; // add incoming byte to end of line
if (inChar == '\n') { // if you get a newline, clear the line
currentLine = "";
if ( currentLine.endsWith("<text>")) { // if the current line ends with <text>, it will be followed by the forecast
readingforecast = true; // Clear the forecast string
forecast = "";
if (readingforecast) { // Add bytes to the forecast String
if (inChar == 'S') {
Serial.println("tomorrow is same");
if(currentTime >= (loopTime + 1000)){
digitalWrite(whitePin, !digitalRead(whitePin)); // toggles white LED on/off
loopTime = currentTime; // Updates loopTime
if (inChar == 'W') {
Serial.println("tomorrow is warmer");
digitalWrite(redPin, !digitalRead(redPin)); // toggles red LED on/off
if (inChar == 'C') {
Serial.println("tomorrow is colder");
digitalWrite(bluePin, !digitalRead(bluePin)); // toggles blue LED on/off
if (inChar != '<') {
forecast += inChar;
else {
readingforecast = false; // End of forecast if "<" character is reached
Serial.println(forecast);
Serial.println("disconnecting...");
client.stop(); // close the connection to the server
else if (millis() - lastAttemptTime > requestInterval) {
connectToServer(); // if you're not connected, and two minutes have passed since your last connection, then attempt to connect again
void connectToServer() {
digitalWrite(whitePin, LOW); // Reset LED to off
digitalWrite(redPin, LOW); // Reset LED to off
digitalWrite(bluePin, LOW); // Reset LED to off
// attempt to connect, and wait a millisecond:
delay(1000); // give the Ethernet shield a second to initialize
Serial.println("connecting...");
if (client.connect(serverName, 80)) { // Connect to server
Serial.println("connected...");
// make HTTP GET request to twitter:
client.println("GET /test.html HTTP/1.0"); // Make a HTTP request
client.println("HOST: lessismorecast.com");
client.println("User-Agent: Arduino 1.0");
client.println();
lastAttemptTime = millis(); // note the time of this connect attempt
