Weather station code not working
I'm trying to set up a personal weather station with Opla IoT Kit using the code from this tutorial: https://opla.arduino.cc/opla/module/iot-starter-kit-maker-long/lesson/personal-weather-station-long
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
  // Initialize serial and wait for port to open:
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  //Get Cloud Info/errors , 0 (only errors) up to 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  //Wait to get cloud connection to init the carrier
  while (ArduinoCloud.connected() != 1) {
    ArduinoCloud.update();
  CARRIER_CASE = false;
  carrier.begin();
  carrier.display.setRotation(0);
  delay(1500);
  carrier.Buttons.update();
  while(!carrier.Light.colorAvailable()) {
    delay(5);
  int none;
  carrier.Light.readColor(none, none, none, light);
  temperature = carrier.Env.readTemperature();
  humidity = carrier.Env.readHumidity();
  pressure = carrier.Pressure.readPressure();
  if (carrier.Buttons.onTouchDown(TOUCH0)) {
    carrier.display.fillScreen(ST77XX_WHITE);
    carrier.display.setTextColor(ST77XX_RED);
    carrier.display.setTextSize(2);
    carrier.display.setCursor(30, 110);
    carrier.display.print("Temp: ");
    carrier.display.print(temperature);
    carrier.display.print(" C");
  if (carrier.Buttons.onTouchDown(TOUCH1)) {
    carrier.display.print("Humi: ");
    carrier.display.print(humidity);
    carrier.display.print(" %");
  if (carrier.Buttons.onTouchDown(TOUCH2)) {
    carrier.display.print("Light: ");
    carrier.display.print(light);
  if (carrier.Buttons.onTouchDown(TOUCH3)) {
    carrier.display.print("Pressure: ");
    carrier.display.print(pressure);
  if (humidity >= 60 && temperature >= 15) {
    weather_report = "It is very humid outside";
  }else if (temperature >= 15 && light >= 700) {
    weather_report = "Warm and sunny outside";
  }else if (temperature <= 16 && light >= 700) {
    weather_report = "A little cold, but sunny outside";
  else{
   weather_report = "Weather is normal";
When I try to upload the code it gives me this error:
/usr/local/bin/arduino-cli compile --fqbn arduino:samd:mkrwifi1010 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/381724684/build --build-path /tmp/arduino-build-23D216F7B4869A0852472D61558A7F52 /tmp/381724684/WeatherStation_mar05a
Using library adafruit_sleepydog_library_1_6_3 at version 1.6.3 in folder: /home/builder/opt/libraries/adafruit_sleepydog_library_1_6_3
Using library adafruit_unified_sensor_1_1_8 at version 1.1.8 in folder: /home/builder/opt/libraries/adafruit_unified_sensor_1_1_8
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp: In member function 'int EnvClass::begin()':
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:39:24: error: 'BME680_I2C_ADDR_PRIMARY' was not declared in this scope
iaqSensor->begin(BME680_I2C_ADDR_PRIMARY, Wire);
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp: In member function 'int AirQualityClass::begin()':
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:38:24: error: 'BME680_I2C_ADDR_PRIMARY' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp: In member function 'int PressureClass::begin()':
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:38:24: error: 'BME680_I2C_ADDR_PRIMARY' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:39:24: note: suggested alternative: 'BME68X_I2C_ADDR_HIGH'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:49:9: error: 'BSEC_OUTPUT_IAQ' was not declared in this scope
BSEC_OUTPUT_IAQ,
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:38:24: note: suggested alternative: 'BME68X_I2C_ADDR_HIGH'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:48:9: error: 'BSEC_OUTPUT_IAQ' was not declared in this scope
BSEC_OUTPUT_IAQ,
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:38:24: note: suggested alternative: 'BME68X_I2C_ADDR_HIGH'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:48:9: error: 'BSEC_OUTPUT_IAQ' was not declared in this scope
BSEC_OUTPUT_IAQ,
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:49:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_GAS
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:50:9: error: 'BSEC_OUTPUT_STATIC_IAQ' was not declared in this scope
BSEC_OUTPUT_STATIC_IAQ,
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:48:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_GAS
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:49:9: error: 'BSEC_OUTPUT_STATIC_IAQ' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:48:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_RAW_GAS
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:49:9: error: 'BSEC_OUTPUT_STATIC_IAQ' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:49:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_RAW_GAS
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:50:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_RAW_GAS
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:50:9: error: 'BSEC_OUTPUT_CO2_EQUIVALENT' was not declared in this scope
BSEC_OUTPUT_CO2_EQUIVALENT,
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:51:9: error: 'BSEC_OUTPUT_CO2_EQUIVALENT' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:49:9: note: suggested alternative: 'BSEC_OUTPUT_RAW_GAS'
BSEC_OUTPUT_RAW_GAS
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:50:9: error: 'BSEC_OUTPUT_CO2_EQUIVALENT' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:50:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:51:9: error: 'BSEC_OUTPUT_BREATH_VOC_EQUIVALENT' was not declared in this scope
BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:51:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:52:9: error: 'BSEC_OUTPUT_BREATH_VOC_EQUIVALENT' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:50:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:51:9: error: 'BSEC_OUTPUT_BREATH_VOC_EQUIVALENT' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:52:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:57:53: error: 'BSEC_SAMPLE_RATE_CONTINUOUS' was not declared in this scope
iaqSensor->updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_CONTINUOUS);
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:51:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:56:53: error: 'BSEC_SAMPLE_RATE_CONTINUOUS' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:51:9: note: suggested alternative: 'BSEC_OUTPUT_IAQ_ESTIMATE'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:56:53: error: 'BSEC_SAMPLE_RATE_CONTINUOUS' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:57:53: note: suggested alternative: 'BSEC_SAMPLE_RATE_ULP'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:56:53: note: suggested alternative: 'BSEC_SAMPLE_RATE_ULP'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp: In member function 'int EnvClass::checkIaqSensorStatus()':
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:76:18: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
if (iaqSensor->status != BSEC_OK) {
bsecStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:77:20: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
if (iaqSensor->status < BSEC_OK) {
bsecStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:82:18: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
if (iaqSensor->bme680Status != BME680_OK) {
bme68xStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:82:34: error: 'BME680_OK' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp: In member function 'int AirQualityClass::checkIaqSensorStatus()':
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:71:18: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:72:20: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:77:18: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:77:34: error: 'BME680_OK' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:56:53: note: suggested alternative: 'BSEC_SAMPLE_RATE_ULP'
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp: In member function 'int PressureClass::checkIaqSensorStatus()':
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:76:18: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:77:20: error: 'class Bsec' has no member named 'status'; did you mean 'bsecStatus'?
bsecStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:82:18: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:82:34: error: 'BME680_OK' was not declared in this scope
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:82:34: note: suggested alternative: 'BME68X_OK'
BME68X_OK
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/EnvClass.cpp:83:20: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
if (iaqSensor->bme680Status < BME680_OK) {
bme68xStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:77:34: note: suggested alternative: 'BME68X_OK'
BME68X_OK
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/AirQualityClass.cpp:78:20: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:82:34: note: suggested alternative: 'BME68X_OK'
BME68X_OK
/home/builder/opt/libraries/latest/arduino_mkriotcarrier_2_0_2/src/PressureClass.cpp:83:20: error: 'class Bsec' has no member named 'bme680Status'; did you mean 'bme68xStatus'?
bme68xStatus
Error during build: exit status 1
I've seen people on YouTube using this code without any problems.
Thanks in advance for your help.
literally, or did you modify it?
I juts copied it
Are you using the same Arduino board as in the tutorial? What IDE version?
Yes, I'm using arduino MKR WiFi 1010
sure, but were they using it?
Yes
Screenshot 2023-03-06 182825
What IDE version?
I'm sorry, but what is IDE?
Integrated Development Environment.
And where can I find out which version am I using?
On the main working screen of the IDE. You might have to click on "About" or something like that. Didn't you install it?
I'm using the IoT cloud web editor. It's version 6.4.7
