Trying to compile the WeatherStationdemo sketch and keep getting Library files not found even though I have downloaded all the libraries as instructed in the Manual.
The persistent one is dht11.h.
Any suggestions most welcome
One suggestion would be to post your code in CODE TAGS.
Another suggestion would be to post an image of your project.
Another suggestion would be to post a schematic.
But my guess is that the code on line 144456 is the issue.
Which MCU is being used?
please read How to get the best out of this forum
Did the Manual tell you where to find the libraries? If it just gave the name of the library, you might have found a different "dht11.h" library. Or the library may have changed since the sketch was written.
The manual instruction was to use Manage Libraries in the Arduino IDE and use search to find and install. i followed the screen shots in the manual but may have downloaded later versions. I will post the sketch below with the latest error.
I did use Manage Libraries to get all that were suggested in the Instruction Manual.
The current error message is :
Arduino: 1.8.4 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash,
Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache +
32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB
OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\i5170\OneDrive\Documents\Arduino\libraries\esp8266-weather-station-master\src\AerisForecasts.cpp: In member function 'void AerisForecasts::doUpdate(AerisForecastData*, String, uint8_t)':
C:\Users\i5170\OneDrive\Documents\Arduino\libraries\esp8266-weather-station-master\src\AerisForecasts.cpp:49:13: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
49 | http.begin(url);
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
#include <ESPWiFi.h>
#include <ESPHTTPClient.h>
#include <JsonListener.h>
// time
#include <time.h> // time() ctime()
#include <sys/time.h> // struct timeval
#include <coredecls.h> // settimeofday_cb()
#include "SSD1306Wire.h"
#include "OLEDDisplayUi.h"
#include "Wire.h"
#include "OpenWeatherMapCurrent.h"
#include "OpenWeatherMapForecast.h"
#include "WeatherStationFonts.h"
#include "WeatherStationImages.h"
#include <ESP8266WiFi.h>
#include <Adafruit_BMP085.h>
* WIFI Settings
const char* WIFI_SSID = "Wifiname";
const char* WIFI_PWD = "password";
* Begin DHT11 Settings
WiFiClient client;
const char *host = "api.thingspeak.com"; //IP address of the thingspeak server
const char *api_key ="6F21LYFFCYATUDUS"; //Your own thingspeak api_key
const int httpPort = 80;
#define pin 14 // ESP8266-12E D5 read emperature and Humidity data
int temp = 0; //temperature
int humi = 0; //humidity
void readTemperatureHumidity();
void uploadTemperatureHumidity();
long readTime = 0;
long uploadTime = 0;
* Begin Atmosphere and Light Sensor Settings
void readLight();
void readAtmosphere();
Adafruit_BMP085 bmp;
const int Light_ADDR = 0b0100011; // address:0x23
const int Atom_ADDR = 0b1110111; // address:0x77
int tempLight = 0;
int tempAtom = 0;
* Begin Settings
#define TZ 2 // (utc+) TZ in hours
#define DST_MN 60 // use 60mn for summer time in some countries
// Setup
const int UPDATE_INTERVAL_SECS = 20 * 60; // Update every 20 minutes
// Display Settings
const int I2C_DISPLAY_ADDRESS = 0x3c;
#if defined(ESP8266)
//const int SDA_PIN = D1;
//const int SDC_PIN = D2;
const int SDA_PIN = D3;
const int SDC_PIN = D4;
#else
//const int SDA_PIN = GPIO5;
//const int SDC_PIN = GPIO4
const int SDA_PIN = GPIO0;
const int SDC_PIN = GPIO2
#endif
// OpenWeatherMap Settings
// Sign up here to get an API key:
// https://docs.thingpulse.com/how-tos/openweathermap-key/
const boolean IS_METRIC = true;
// Add your own thingpulse ID
String OPEN_WEATHER_MAP_APP_ID = "ed121a12e29d5b9d0e15a68de9a6f88e";
String OPEN_WEATHER_MAP_LOCATION = "Zurich,CH";
// Pick a language code from this list:
// Arabic - ar, Bulgarian - bg, Catalan - ca, Czech - cz, German - de, Greek - el,
// English - en, Persian (Farsi) - fa, Finnish - fi, French - fr, Galician - gl,
// Croatian - hr, Hungarian - hu, Italian - it, Japanese - ja, Korean - kr,
// Latvian - la, Lithuanian - lt, Macedonian - mk, Dutch - nl, Polish - pl,
// Portuguese - pt, Romanian - ro, Russian - ru, Swedish - se, Slovak - sk,
// Slovenian - sl, Spanish - es, Turkish - tr, Ukrainian - ua, Vietnamese - vi,
// Chinese Simplified - zh_cn, Chinese Traditional - zh_tw.
String OPEN_WEATHER_MAP_LANGUAGE = "en";
const uint8_t MAX_FORECASTS = 4;
// Adjust according to your language
const String WDAY_NAMES[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
const String MONTH_NAMES[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
* End Settings
// Initialize the oled display for address 0x3c
SSD1306Wire display(I2C_DISPLAY_ADDRESS, SDA_PIN, SDC_PIN);
OLEDDisplayUi ui( &display );
OpenWeatherMapCurrentData currentWeather;
OpenWeatherMapCurrent currentWeatherClient;
OpenWeatherMapForecastData forecasts[MAX_FORECASTS];
OpenWeatherMapForecast forecastClient;
#define TZ_MN ((TZ)*60)
#define TZ_SEC ((TZ)*3600)
#define DST_SEC ((DST_MN)*60)
time_t now;
// flag changed in the ticker function every 10 minutes
bool readyForWeatherUpdate = false;
String lastUpdate = "--";
long timeSinceLastWUpdate = 0;
//declaring prototypes
void drawProgress(OLEDDisplay *display, int percentage, String label);
void updateData(OLEDDisplay *display);
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state);
void setReadyForWeatherUpdate();
// Add frames
// this array keeps function pointers to all frames
// frames are the single views that slide from right to left
FrameCallback frames[] = { drawDateTime, drawCurrentWeather, drawForecast };
int numberOfFrames = 3;
OverlayCallback overlays[] = { drawHeaderOverlay };
int numberOfOverlays = 1;
Wire.begin(0,2);
Wire.beginTransmission(Atom_ADDR);
//initialize Atmosphere sensor
if (!bmp.begin()) {
Serial.println("Could not find BMP180 or BMP085 sensor at 0x77");
}else{
Serial.println("Find BMP180 or BMP085 sensor at 0x77");
Wire.endTransmission();
//initialize light sensor
Wire.beginTransmission(Light_ADDR);
Wire.write(0b00000001);
// initialize dispaly
display.init();
display.clear();
display.display();
//display.flipScreenVertically();
display.setFont(ArialMT_Plain_10);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setContrast(255);
WiFi.begin(WIFI_SSID, WIFI_PWD);
int counter = 0;
Serial.print(".");
display.clear();
display.drawString(64, 10, "Connecting to WiFi");
display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
display.display();
counter++;
// Get time from network time service
configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
ui.setTargetFPS(30);
ui.setActiveSymbol(activeSymbole);
ui.setInactiveSymbol(inactiveSymbole);
// You can change this to
// TOP, LEFT, BOTTOM, RIGHT
ui.setIndicatorPosition(BOTTOM);
// Defines where the first frame is located in the bar.
ui.setIndicatorDirection(LEFT_RIGHT);
// You can change the transition that is used
// SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
ui.setFrameAnimation(SLIDE_LEFT);
ui.setFrames(frames, numberOfFrames);
ui.setOverlays(overlays, numberOfOverlays);
// Inital UI takes care of initalising the display too.
ui.init();
Serial.println("");
updateData(&display);
while (!client.connect(host, httpPort)) {
Serial.println("Connection Failed");
//Read Temperature Humidity every 5 seconds
if(millis() - readTime > 5000){
readLight();
readAtmosphere();
readTime = millis();
//Upload Temperature Humidity every 60 seconds
if(millis() - uploadTime > 60000){
uploadTime = millis();
if (millis() - timeSinceLastWUpdate > (1000L*UPDATE_INTERVAL_SECS)) {
timeSinceLastWUpdate = millis();
if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {
int remainingTimeBudget = ui.update();
if (remainingTimeBudget > 0) {
// You can do some work here
// Don't do stuff if you are below your
// time budget.
delay(remainingTimeBudget);
void drawProgress(OLEDDisplay *display, int percentage, String label) {
display->clear();
display->setTextAlignment(TEXT_ALIGN_CENTER);
display->setFont(ArialMT_Plain_10);
display->drawString(64, 10, label);
display->drawProgressBar(2, 28, 124, 10, percentage);
display->display();
void updateData(OLEDDisplay *display) {
drawProgress(display, 10, "Updating time...");
drawProgress(display, 30, "Updating weather...");
currentWeatherClient.setMetric(IS_METRIC);
currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
currentWeatherClient.updateCurrent(¤tWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION);
drawProgress(display, 50, "Updating forecasts...");
forecastClient.setMetric(IS_METRIC);
forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
uint8_t allowedHours[] = {12};
forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
forecastClient.updateForecasts(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION, MAX_FORECASTS);
drawProgress(display, 100, "Done...");
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
now = time(nullptr);
struct tm* timeInfo;
timeInfo = localtime(&now);
char buff[16];
String date = WDAY_NAMES[timeInfo->tm_wday];
sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon+1, timeInfo->tm_year + 1900);
display->drawString(64 + x, 5 + y, String(buff));
display->setFont(ArialMT_Plain_24);
sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
display->drawString(64 + x, 15 + y, String(buff));
display->setTextAlignment(TEXT_ALIGN_LEFT);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
display->drawString(64 + x, 38 + y, currentWeather.description);
String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
display->drawString(60 + x, 5 + y, temp);
display->setFont(Meteocons_Plain_36);
display->drawString(32 + x, 0 + y, currentWeather.iconMeteoCon);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
drawForecastDetails(display, x, y, 0);
drawForecastDetails(display, x + 44, y, 1);
drawForecastDetails(display, x + 88, y, 2);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
time_t observationTimestamp = forecasts[dayIndex].observationTime;
timeInfo = localtime(&observationTimestamp);
display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
display->setFont(Meteocons_Plain_21);
display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
display->drawString(x + 20, y + 34, temp);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
char buff[14];
sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
display->setColor(WHITE);
display->drawString(0, 54, String(buff));
display->setTextAlignment(TEXT_ALIGN_RIGHT);
display->drawString(128, 54, temp);
display->drawHorizontalLine(0, 52, 128);
void setReadyForWeatherUpdate() {
Serial.println("Setting readyForUpdate to true");
readyForWeatherUpdate = true;
//read temperature humidity data
void readTemperatureHumidity(){
int j;
unsigned int loopCnt;
int chr[40] = {0};
unsigned long time1;
bgn:
delay(2000);
//Set interface mode 2 to: output
//Output low level 20ms (>18ms)
//Output high level 40μs
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
delay(20);
digitalWrite(pin, HIGH);
delayMicroseconds(40);
//Set interface mode 2: input
pinMode(pin, INPUT);
//High level response signal
loopCnt = 10000;
while (digitalRead(pin) != HIGH){
if (loopCnt-- == 0){
//If don't return to high level for a long time, output a prompt and start over
Serial.println("HIGH");
goto bgn;
//Low level response signal
loopCnt = 30000;
while (digitalRead(pin) != LOW){
//If don't return low for a long time, output a prompt and start over
Serial.println("LOW");
goto bgn;
//Start reading the value of bit1-40
for (int i = 0; i < 40; i++){
while (digitalRead(pin) == LOW){}
//When the high level occurs, write down the time "time"
time1 = micros();
while (digitalRead(pin) == HIGH){}
//When there is a low level, write down the time and subtract the time just saved
//If the value obtained is greater than 50μs, it is ‘1’, otherwise it is ‘0’
//And save it in an array
if (micros() - time1 > 50){
chr[i] = 1;
chr[i] = 0;
//Humidity, 8-bit bit, converted to a value
humi = chr[0] * 128 + chr[1] * 64 + chr[2] * 32 + chr[3] * 16 + chr[4] * 8 + chr[5] * 4 + chr[6] * 2 + chr[7];
//Temperature, 8-bit bit, converted to a value
temp = chr[16] * 128 + chr[17] * 64 + chr[18] * 32 + chr[19] * 16 + chr[20] * 8 + chr[21] * 4 + chr[22] * 2 + chr[23];
Serial.print("temp:");
Serial.print(temp);
Serial.print(" humi:");
Serial.println(humi);
void readLight(){
// reset
Wire.write(0b00000111);
Wire.write(0b00100000);
// typical read delay 120ms
delay(120);
Wire.requestFrom(Light_ADDR, 2); // 2byte every time
for (tempLight = 0; Wire.available() >= 1; ) {
char c = Wire.read();
tempLight = (tempLight << 8) + (c & 0xFF);
tempLight = tempLight / 1.2;
Serial.print("light: ");
Serial.println(tempLight);
void readAtmosphere(){
tempAtom = bmp.readPressure();
Serial.print("Pressure = ");
Serial.print(tempAtom);
Serial.println(" Pascal");
//upload temperature humidity data to thinkspak.com
void uploadTemperatureHumidity(){
if(!client.connect(host, httpPort)){
Serial.println("connection failed");
return;
// Three values(field1 field2 field3 field4) have been set in thingspeak.com
client.print(String("GET ") + "/update?api_key="+api_key+"&field1="+temp+"&field2="+humi + "&field3="+tempLight+"&field4="+tempAtom+" HTTP/1.1\r\n" +"Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
The OP did notice the error message? Has the OP did as error message suggests?
Sorry, I was just focused on the prior library errors. The compiler must have moved on.
Does that mean, the error is now about the URl and API keys?
I will try to input my API keys and the website URLs.
I put in my API key, but still getting the same error.
Does the code have to be changed? The sketch was not written my me.
It was downloaded from the weather station website so I am assuming it should be correct.
The 'esp8266-weather-station-master' library is using http.begin() in a way that is no longer supported. Open the file 'src\AerisForecasts.cpp' in that library and change line 49 from:
http.begin(url);
to
http.begin(client, url);
For 'client', use whatever name was given to the WiFiClient.
Thanks so much. I have been reading several threads about this error
The solutions are discussed in cryptic terms, was hard to figure it out. I was not aware that libraries could be edited. I was looking for the error lines in the sketch! I'll work on it now and hopefully get it to compile and load.
I tried this, but unfortunately, got an error suggesting capital 'C" now i get this error:AerisForecasts.cpp:49:20: error: expected primary-expression before ',' token 49 | http.begin(Client,url); | ^ Multiple libraries were found for "ESPWiFi.h" Used: C:\Users\i5170\OneDrive\Documents\Arduino\libraries\esp8266-weather-station-master Not used: C:\Users\i5170\OneDrive\Documents\Arduino\libraries\ESP8266_Weather_Station Not used: C:\Users\i5170\OneDrive\Documents\Arduino\libraries\ESP8266_Weather_Station Not used: C:\Users\i5170\OneDrive\Documents\Arduino\libraries\ESP8266_Weather_Station Not used: C:\Users\i5170\OneDrive\Documents\Arduino\libraries\ESP8266_Weather_Station exit status 1 Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Have tried searching online with similar errors but
no success so far.
Where did you get your "AerisForecasts.cpp"? The one I found in GitHub does not have the code you are having trouble with.
The area around line 49 does not contain "http.begin()":
void AerisForecasts::doUpdate(AerisForecastData *forecasts, String path, uint8_t maxForecasts) {
this->maxForecasts = maxForecasts;
this->currentForecast = 0;
unsigned long lostTest = 10000UL;
unsigned long lost_do = millis();
this->forecasts = forecasts;
JsonStreamingParser parser;
parser.setListener(this);
Serial.printf("[HTTP] Requesting resource at http://%s:%u%s\n", host.c_str(), port, path.c_str());
WiFiClient client;
if(client.connect(host, port)) {
bool isBody = false;
char c;
Serial.println("[HTTP] connected, now GETting data");
client.print("GET " + path + " HTTP/1.1\r\n"
while (client.connected() || client.available()) {
It was all in a zip file from here: GitHub - GJKJ/WSK: WTS
I got that link from the Banggood page where I bought the kit.
I will try to modify my file to match the above. Thanks.
Success! Thanks so much.
There were other lines in the code that were different as well, so instead of just editing one line, I thought it best to replace the whole file.
I moved the whole Weather Station master folder out of the Library and replaced with the folder extracted from the Zip in your link.
My weather Station is now working.!!!
In trouble shooting this issue, I also download other example sketches and learnt that the ESP8266 only operates on 2.4GHz. So was able to fix that. Then looking for other #include files I learnt that Arduino saves files in 3 separate libraries including:
C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src
Yay!
