weather station ESP8266 Nond MCU developement board 12E error
Keep getting message, looked in the directory that shows in the error message that says no such file or directory but yet it exist.
Program:
<ArduinoJson.h>
#include <Adafruit_Sensor.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <DHT.h>
#define DHTTYPE DHT11
#define DHTPIN 14
#define WLAN_SSID "NETGEAR41"
#define WLAN_PASSWORD "freshocean613"
DHT dht(DHTPIN, DHTTYPE, 11);
ESP8266WebServer server(80);
float temperature, humidity;
unsigned long previousMillis = 0;
const long interval = 2000;
delay(10);
dht.begin();
humidity = dht.readHumidity();
temperature = dht.readTemperature();
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.mode(WIFI_STA);
WiFi.begin(WLAN_SSID, WLAN_PASSWORD);
Serial.print(".");
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
server.on("/dht11", HTTP_GET, {
if (currentMillis - previousMillis >= interval) {
if (isnan(humidity) || isnan(temperature)) {
Serial.println("Failed to read from DHT sensor!");
return;
String webString = "Humiditiy " + String((int)humidity) + "% Temperature: " + String((int)temperature) + " C";
Serial.println(webString);
server.send(200, "text/plain", webString);
server.on("/dht11.json", {
return;
Serial.println("Reporting " + String((int)temperature) + "C and " + String((int)humidity) + " % humidity");
StaticJsonBuffer<500> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
root["temperature"] = temperature;
root["humidity"] = humidity;
String jsonString;
root.printTo(jsonString);
Serial.println(jsonString);
server.send(200, "application/json", jsonString);
server.begin();
Serial.println("HTTP server started! Waiting for clients!");
server.handleClient();
Error message verbose:
Arduino: 1.8.2 (Windows 10), Board: "ESPDuino (ESP-13 Module), 80 MHz, 115200, 4M (3M SPIFFS)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HP\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HP\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HP\Documents\Arduino\libraries -fqbn=esp8266:esp8266:espduino:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10802 -build-path C:\Users\HP\AppData\Local\Temp\arduino_build_512855 -warnings=none -build-cache C:\Users\HP\AppData\Local\Temp\arduino_cache_462811 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\HP\Documents\Arduino\weatherStationESP8266\weatherStationESP8266.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HP\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HP\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HP\Documents\Arduino\libraries -fqbn=esp8266:esp8266:espduino:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10802 -build-path C:\Users\HP\AppData\Local\Temp\arduino_build_512855 -warnings=none -build-cache C:\Users\HP\AppData\Local\Temp\arduino_cache_462811 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\HP\Documents\Arduino\weatherStationESP8266\weatherStationESP8266.ino
Using board 'espduino' from platform in folder: C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Build options changed, rebuilding all
Detecting libraries used...
"C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\HP\AppData\Local\Temp\arduino_build_512855/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10802 -DARDUINO_ESP8266_ESP13 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP13" -DESP8266 "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\ESPDuino" "C:\Users\HP\AppData\Local\Temp\arduino_build_512855\sketch\weatherStationESP8266.ino.cpp" -o "nul"
"C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\HP\AppData\Local\Temp\arduino_build_512855/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10802 -DARDUINO_ESP8266_ESP13 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP13" -DESP8266 "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\ESPDuino" "C:\Users\HP\AppData\Local\Temp\arduino_build_512855\sketch\weatherStationESP8266.ino.cpp" -o "C:\Users\HP\AppData\Local\Temp\arduino_build_512855\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\HP\Documents\Arduino\weatherStationESP8266\weatherStationESP8266.ino:7:29: fatal error: Adafruit_Sensor.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board ESPDuino (ESP-13 Module).
Can someone direct me here, thank you.
I used the right board this time , loaded the wrong one by mistake but still got the same message.
Arduino: 1.8.2 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HP\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HP\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HP\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10802 -build-path C:\Users\HP\AppData\Local\Temp\arduino_build_512855 -warnings=none -build-cache C:\Users\HP\AppData\Local\Temp\arduino_cache_462811 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\HP\Documents\Arduino\weatherStationESP8266\weatherStationESP8266.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HP\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HP\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HP\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10802 -build-path C:\Users\HP\AppData\Local\Temp\arduino_build_512855 -warnings=none -build-cache C:\Users\HP\AppData\Local\Temp\arduino_cache_462811 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\HP\Documents\Arduino\weatherStationESP8266\weatherStationESP8266.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
"C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\HP\AppData\Local\Temp\arduino_build_512855/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10802 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\HP\AppData\Local\Temp\arduino_build_512855\sketch\weatherStationESP8266.ino.cpp" -o "nul"
"C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\HP\AppData\Local\Temp\arduino_build_512855/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10802 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\HP\AppData\Local\Temp\arduino_build_512855\sketch\weatherStationESP8266.ino.cpp" -o "C:\Users\HP\AppData\Local\Temp\arduino_build_512855\preproc\ctags_target_for_gcc_minus_e.cpp"
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
The message does NOT tell you what directory Adafruit_Sensor.h should be in. So, what directory IS it in?
