Weather Station LCD problem
anybody help ive got this code below which uploads ok, but lcd flickers and doesnt cycle through using a push button anyone help whats wrong or come across this before ??
#include <dht11.h>
#include <LiquidCrystal.h>
//initialize DHT11
dht11 DHT11;
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//pin declaration
int lightPin = A0;
int dhtPin = A1;
int buttonPin = 7;
unsigned long cur = 0;
unsigned long measurementFrequency = 1000;
unsigned long lastMeasurement = 0;
int measurementValue = 0;
int lastButtonState = LOW;
unsigned long lastDebounce = 0;
unsigned long buttonDebounceDelay = 250;
int currMode = 0;
boolean modeChanged = false;
boolean isPing = false;
unsigned long lastPing = 0;
unsigned long pingDelay = 250;
  //debug
  //Serial.begin(9600);
  //setup LCD
  lcd.begin(16,2);
  //print welcome text
  lcd.setCursor(3,0);
  lcd.print("Welcome to");
  lcd.setCursor(2,1);
  lcd.print("Electronics!");
  delay(3000);
  lcd.clear();
  //record current time in milliseconds
  cur = millis();
  //see if we need to measure
  if ((cur - lastMeasurement > measurementFrequency) || modeChanged) {
    //control members
    lastMeasurement = cur;
    lastPing = cur;
    //do the work
    measureAndDisplay();
    //make the ping (blink an asterisk)
    ping();
    //check if blinking
    if (isPing && cur - lastPing > pingDelay) pong();
    //monitor if button pressed
    int currentButtonState = digitalRead(buttonPin);
    if ((currentButtonState != lastButtonState) && (currentButtonState == HIGH) && (cur - lastDebounce > buttonDebounceDelay))
      lastDebounce = cur;
    if (currMode == 2) currMode = 0;
    else currMode = currMode + 1;
    modeChanged = true;
  //debug
  //Serial.println(currentButtonState)
void measureAndDisplay() {
  //clear the display
  lcd.clear();
  switch (currMode) {
    //0: temperature - read DHT11.temperature and write it out
  case 0:
    DHT11.read(dhtPin);
    measurementValue = DHT11.temperature;
    lcd.setCursor(2,0);
    lcd.print("Temperature:");
    lcd.setCursor(2,1);
    lcd.print(measurementValue);
    lcd.print(char(223));
    lcd.print("C - ");
    int toFarenheit;
    toFarenheit = (measurementValue * 1.8 + 32);
    //for our American friends
    lcd.print(toFarenheit);
    lcd.print("F");
  case 1:
    //1: humidity - read DHT11.humidity and write it out in %
    measurementValue = DHT11.humidity;
    lcd.setCursor(4,0);
    lcd.print("Humidity");
    lcd.setCursor(7,1);
    lcd.print("%");
  case 2:
    //2: light intensity - read the light sensor and output the value in %.
    //This can be converted into Lux, but I believe this setup is not precise enough.
    measurementValue = analogRead(lightPin);
    measurementValue = map(measurementValue, 0, 1023, 100, 0);
    lcd.setCursor(0,0);
    lcd.print("Light Intensity");
    lcd.setCursor(7,1);
    lcd.print("%");
//show asterisk
void ping()
  lcd.setCursor(15,1);
  lcd.print("*");
  isPing = true;
  //debug
  //Serial.println("Ping");
//clear asterisk
void pong()
  lcd.print(" ");
  isPing = false;
  //debug
  //Serial.println("Pong")
whats wrong
No capital letters + no punctuation == childishness == no help.
You also failed to describe how your switch is wired.
load the ardiuno uno up with the programme and instead of cycling through the lux, temp, and humidity it flickers with all 3. i know the lcd works and is connected correctly because i can upload the basic "hello world" programme
    //check if blinking
      lastDebounce = cur;
    modeChanged = true;
What's with the curly braces around this code?
Where are the capital letters?
Where is the answer to how your switch is wired?
