Weather Station LED Flickering
So, my creation is a weather station that tells me what to wear depending on the temperature, and light up an RGB LED, and it will Pulse Red, Green, Blue or a mix of colors. I got the PWM and Pulsing working, but the LED seems to flicker then pulse. I cannot seem to figure out why.
Can you guys review my coding and watch the video, then give some suggestions.
#include <LiquidCrystal.h> // includes math and LCD libraries
#include <math.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initalizes the pins the LCD screen will use.
int Temperature = analogRead(0); //Thermistor connected to Analog "0" and the "Temperature" integer is equal to analogRead of pin A0.
int indicatorHot = 5; // Hot LED on D13
int indicatorNorm = 9; // Norm LED on D9
int indicatorCold = 6; // Cold LED on D8
double Thermister(int RawADC) // the Thermister is going to convert an integer which is the Raw ADC, some type or raw current from the Thermister
  double Temp;
  Temp = log(((10240000/RawADC) - 10000));
  Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp ); // this converts the raw crap into Kelvin...
  Temp = Temp - 273.15; // Converting Kelvin into Celsius
  Temp = (Temp * 9.0)/ 5.0 + 32.0; // Converting Celsius into Fahrenheit
  return Temp;
void setup() // setup procedure runs once...actually has no purpose other than to show the faux startup screen, and run through and test the LEDs
  pinMode(indicatorHot, OUTPUT); //defines indicator Pins as outputs
  pinMode(indicatorNorm, OUTPUT);
  pinMode(indicatorCold, OUTPUT);
  for(int fadeValue = 0; fadeValue <= 100; fadeValue +=10)
    // sets the value (range from 0 to 100):
    analogWrite(indicatorHot, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
    // fade out from max to min in increments of 5 points:
    analogWrite(indicatorNorm, fadeValue);
    delay(30);
  for(int fadeValue = 100; fadeValue >= 0; fadeValue -=10)
    delay(30);
    analogWrite(indicatorCold, fadeValue);
    delay(30);
    delay(30);
    // fade out from max to min in increments of 10 points:
    delay(30);
  lcd.begin(16,2); // begins the LCD screen and defines the columns, rows
  lcd.clear(); // clears LCD screen
  lcd.cursor(); // turns cursor on and blinks to look cool
  delay(100);
  lcd.noCursor();
  delay(100);
  lcd.cursor();
  delay(100);
  lcd.autoscroll();
  lcd.noCursor();
  lcd.print("Sexy Weatherduino Station"); // displays projects name
  lcd.setCursor(0,2); // moves cursor
  lcd.cursor(); // blinks cursor again to simulate loading
  delay(100);
  lcd.noCursor();
  delay(100);
  lcd.cursor();
  delay(100);
  lcd.noCursor();
  lcd.print("beginning startup"); // simulates a program loading screen type thing with dots appearing as time progresses for 3 seconds
  lcd.print("beginning startup.");
  lcd.print("beginning startup..");
  lcd.print("beginning startup...");
  lcd.print("Fahrenheit:"); //displays Fahrenheit so you know what the god damn numbers stand for.
  lcd.print(int(Thermister(analogRead(0)))); // calls the Thermister function, which reads the voltage from "A0" and then displays its value as an integer.
  if (int(Thermister(analogRead(0))) > 80) // if the temperature returned from the function is greater than 80 (in degrees) display the following
    Serial.println(int(Thermister(analogRead(0))));
    for(int fadeValue = 0; fadeValue <= 255; fadeValue +=5)
      // sets the value (range from 0 to 255):
      delay(10);
    for(int fadeValue = 255; fadeValue >= 0; fadeValue -=5)
      delay(10);
    lcd.setCursor(0,2);
    lcd.autoscroll();
    lcd.print("its hot.");
    delay(100);
    lcd.print("its hot. take off your clothes.");
    delay(100);
    lcd.print("its hot. take off your clothes..");
    delay(100);
    lcd.print("its hot. take off your clothes...");
  else if (int(Thermister(analogRead(0))) > 45) // if the temperature returned from the function is greater than 45 (in degrees) display the following
      delay(10);
      delay(10);
    lcd.setCursor(0,2);
    lcd.autoscroll();
    lcd.print("its mild out keep your clothes on");
    delay(100);
    lcd.print("its mild out keep your clothes on.");
    delay(100);
    lcd.print("its mild out keep your clothes on..");
    delay(100);
    lcd.print("its mild out keep your clothes on...");
  else if (int(Thermister(analogRead(0))) > 30) // if the temperature returned from the function is greater than 45 (in degrees) display the following
      delay(10);
      delay(10);
    lcd.setCursor(0,2);
    lcd.autoscroll();
    lcd.print("its cool out, may want a sweater vest");
    delay(100);
    lcd.print("its cool out, may want a sweater vest.");
    delay(100);
    lcd.print("its cool out, may want a sweater vest..");
    delay(100);
    lcd.print("its cool out, may want a sweater vest...");
  else  // if the temperature returned from the function is doesnt fit the upper stuff display this
      delay(10);
      delay(10);
    lcd.setCursor(0,2);
    lcd.autoscroll();
    lcd.print("its a tit bit nipply out");
    delay(100);
    lcd.print("its a tit bit nipply out.");
    delay(100);
    lcd.print("its a tit bit nipply out..");
    delay(100);
    lcd.print("its a tit bit nipply out...");
I'm guessing its the three
delay(100);
statements in the lcd writing areas.
Why do you write the statements 4 times?
CrossRoads:
what do you mean write the statements four times?
the lcd.print statement? if thats your question, its because its supposed to look like it goes
and so it looks like the periods pop up after the text is printed.
I see, didn't notice the periods.
You could rewrite the code in "blink without delay" style
Check to see if 10mS has gone by, if so do one change of the fade up/down and write out a letter,
have some flags so you can keep track of what is going on.
Will let it look like things are happening more in parallel then.
Thanks a bunch i will try that out and see what happens!
