Weather station PONG ERROR CODE
amateur at this programming trying to build a weather station got a code off the net and get a pong error code and cant see where i have gone wrong can anyone help please ???
ive highlighted which bit has gone wrong can someone help.
#include <dht11.h>
#include <LiquidCrystal.h>
//initialize DHT11
dht11 DHT11;
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//pin declaration
int lightPin = A0;
int dhtPin = A1;
int buttonPin = 7;
unsigned long cur = 0;
unsigned long measurementFrequency = 1000;
unsigned long lastMeasurement = 0;
int measurementValue = 0;
int lastButtonState = LOW;
unsigned long lastDebounce = 0;
unsigned long buttonDebounceDelay = 250;
int currMode = 0;
boolean modeChanged = false;
boolean isPing = false;
unsigned long lastPing = 0;
unsigned long pingDelay = 250;
  //debug
  //Serial.begin(9600);
  //setup LCD
  lcd.begin(16,2);
//print welcome text
lcd.setCursor(3,0);
lcd.print("Welcome to");
lcd.setCursor(2,1);
lcd.print("Electronics!");
delay(3000);
lcd.clear();
  //record current time in milliseconds
  cur = millis();
 //see if we need to measure
 if ((cur - lastMeasurement > measurementFrequency) || modeChanged) {
 //control members
 lastMeasurement = cur;
 lastPing = cur;
 //do the work
 measureAndDisplay();
 //make the ping (blink an asterisk)
 ping();
 //check if blinking
 [glow=yellow,2,300][b]if (isPing && cur - lastPing > pingDelay) pong(); [/b] [/glow]
 //monitor if button pressed
 int currentButtonState = digitalRead(buttonPin);
 if ((currentButtonState != lastButtonState) && (currentButtonState == HIGH) && (cur - lastDebounce > buttonDebounceDelay))
   lastDebounce = cur;
   if (currMode == 2) currMode = 0;
   else currMode = currMode + 1;
   modeChanged = true;
//debug
//Serial.println(currentButtonState);
void measureAndDisplay() {
  //clear the display
  lcd.clear();
  switch (currMode) {
    //0: temperature - read DHT11.temperature and write it out
    case 0:
    DHT11.read(dhtPin);
    measurementValue = DHT11.temperature;
    lcd.setCursor(2,0);
    lcd.print("Temperature:");
    lcd.setCursor(2,1);
    lcd.print(measurementValue);
    lcd.print(char(223));
    lcd.print("C - ");
    int toFarenheit;
    toFarenheit = (measurementValue * 1.8 + 32);
    //for our American friends
    lcd.print(toFarenheit);
    lcd.print("F");
    case 1:
    //1: humidity - read DHT11.humidity and write it out in %
    measurementValue = DHT11.humidity;
    lcd.setCursor(4,0);
    lcd.print("Humidity");
    lcd.setCursor(7,1);
    lcd.print("%");
     case 2:
     //2: light intensity - read the light sensor and output the value in %.
     //This can be converted into Lux, but I believe this setup is not precise enough.
     measurementValue = analogRead(lightPin);
     measurementValue = map(measurementValue, 0, 1023, 100, 0);
     lcd.setCursor(0,0);
     lcd.print("Light Intensity");
     lcd.setCursor(7,1);
     lcd.print("%");
   //show asterisk
   void ping()
     lcd.setCursor(15,1);
     lcd.print("*");
     isPing = true;
     //debug
     //Serial.println("Ping");
//clear asteriskvoid pong()
lcd.print(" ");
isPing = false;
//debug
//Serial.println("Pong");
Something to do with this?
sorry it didnt hightlight
its this part.
//check if blinking
if (isPing && cur - lastPing > pingDelay) pong;
get these error codes
weather_Station.ino: In function 'void loop()':
weather_Station:72: error: 'pong' was not declared in this scope
weather_Station:77: error: expected primary-expression before '}' token
weather_Station:77: error: expected `;' before '}' token
weather_Station.ino: At global scope:
weather_Station:145: error: expected unqualified-id before '{' token
That is not how to call a function.
Where is that function defined? Pay attention to what you are commenting out/deleting.
thought this was how pong was defined. total amateur here
you can't define anything in a comment.
Slip in a new line before the "void"
Don't forget the () on the call, too.
thanks didnt see that at all.
ok got that working sorry to be a pain now got a problem with the measureAndDisplay
got
weather_Station:63: error: 'measureAndDisplay' was not declared in this scope
weather_Station:91: error: a function-definition is not allowed here before '{' token
 //do the work
 ping();
You need to use Tools + Auto Format to properly indent your code. Then, you can see where loop() ends, and where you have code outside of a function (which is not allowed).
