Hi everyone. I'm building a weather station project with "Weather Shield" of Sparkfun and I was able to visualize the data through the connection with arduino uno.
Now I need to publish the data in the Azure cloud through WiFi and I can't think of how to do it. I have an ESP32 available. Can anybody help me?
Briefly describe "Azure cloud". I suspect the process of describing what you believe it is will shed some light on your task.
I'm curious to know why you chose Azure over the other service providers.
On my company we manage the entire data system in the Azure cloud.
Wow. What an amazing coincidence. Early today I read an article about Escher sentence and you post one.
Haha! I have no idea how to proceed with the project. Can you help me with something?
This isn't really an Arduino question - what do you have running in Azure that you want to send your data to?
Azure cloud doesn't mean much to me. Do you have Azure servers, some service hosted there to accept data, a SQL db?
We have contracted an Azure DataLake and Synapse services. Actually hace a SQL database in Azure.
Ultimately you're going to need to hit an API somewhere with your data. The specifics of that are something to discuss with your Azure guys.
From the ESP32 side, take a look for WiFi client examples. Your Uno can talk to it over Serial to pass the data and then the ESP can transmit it to Azure, assuming it can get out through your firewall.
Do you have any idea about connect weather shield to ESP32 to transmit data? That's my only problem.
Sparkfun docs say it will work at 3V, so you could attach it directly to the ESP. Alternatively, since you already have it working with the Uno, you could send the output you have now over serial (don't forget a level shifter), parse it on the ESP and then use WiFi to send it to Azure.
