Weatherproof DC Motor on Car Roof
I'm creating a sort of scissor jack lift that will be mounted to the top of my truck. There will be 3 motors that will raise a platform up and down. The platform will be laying on top of the motors so it'll be somewhat shielded by the elements.
My question is how do I try to weatherproof the motors from humidity, snow, etc. Will using a BLDC be a better choice than brushed? I think I've read somewhere that soaking the shaft in some kind of oil works. Thanks!
Clearly you either buy a (geared) motor that is specifically designed to be weatherproof, or you do not.
Long ago, we used an aircraft flap motor (ex-WWII disposals) to rotate an antenna on the car roof rack. I imagine that was designed to be reasonably weatherproof. :grin:
Do you know where you would source that kind of motor? I've looked at cytron, servocity, and adafruit but I can't find anything. Thanks!
Not sure how you linkage will work but you might look into an automotive wiper or window lift motors. Both are in a location that will get wet periodically.
The one I referenced was part of the flood of "disposals" items that followed World War II. That sort of thing does not tend to happen these days. :woozy_face:
What was good about it was the heavy gearing. A windscreen wiper motor would not provide (anywhere near) as much torque and it sounds like you need substantial gearing for a scissor lift. A window motor just might if the load is not heavy.
