I finished my little weatherstation project with a outdoor sensor unit using XBEE and solar power.
For more information and a photo tutorial about how to set up the units have a look here: http://tinyurl.com/6bk5bvo
Enjoy it!
Axel
Enjoy it!
Axel
Looks good.
Rob
Very neat looking.
That switch your using sure is expensive ![]()
I was looking at the light up ones and they're rather more than I'm willing to spend - but they do look cool ![]()
Thanks!
I like the switch too... it's vandalism proof, costs 6,30 €. Not so much compared to the rest of the compartment.
Nice project! i hope to make something similar soon with one more component.
I want to also use a WiShield to send the data to a web page.
Right now I'm learnig how XBEEs work.
Was it hard to integrate the solar panel aspect of this project?
Thank you!
I had some problems with the LiPoly charger, destroyed 2 of them. I suppose, the voltage from the solar panels has been to high (even so rated at 6V, input max for the charger 7V). Therefore I added a voltage regulator to keep the voltage at 5V. Otherwise the mechanical work has been the hardest. I found it hard to integrate a webserver into the system, therefore I setup a datalogger with webserver capability (see same forum).
Please present your results here in the forum! Looking forward to it.
Axel
Very cool! Where did you get that enclosure and how much?
Its a BOPLA ET-205 (4€) and ET-227 (13€), bought at www.reichelt.de
Greetings,
Axel
Axel,
Am looking to build your weather station for my Opa in Furth,but am having difficulty finding a 20x4 Serial LCD. Could you point me to where you purchased it from so that I don't have to re-write the code for an I2C 20x4 LCD.
Thanks,
Martin
If you take my phi-panel and saw off the keyboard, ... ![]()
Hi Martin,
sorry for the late reply, have been on a trip.
I bought the display from www.watterott.com, part no: LCD-09568
http://www.watterott.com/de/20x4-Zeichen-LED-gelb/gruen-serielle-Ansteuerung.
But they should be available also from www.tinkersoup.de or sparkfun.
Good luck with your project.
Axel
Looking good, but reading through the pdf files I noticed it says you are using li-ion batteries for the transmitter.
Isn't it li-po batteries? I got a li-po battery, looking exactly like yours, and you are also using a li-po charger for the battery.
Actually the battery is called polymer lithium ion - you are right!
Axel
Axel:
Greetings,
Axel
Hi Axel,
what about the enclosure shown in your first post?.
"DG2AB"?
DG2AB is my Ham Radio call....
The enclosure is a TEKO AUS22 bought at www.reichelt.de
Axel
