web controlled digital outputs
Hi all
Newbie Looking for some help with my sketch, i have ditigal outputs programed for web control the problem i have is the outputs don’t latch when triggered i only get a momentry pulse what iam looking for is when triggered to latch on until i send an off command, being very new to arduino i have used free code to start my sketch with a few modifications on my own
any help much appreciated
Z
Please see code below
// LOAD LIBRARY
#include <Ethernet.h>
#include <SPI.h>
boolean reading = false;
//CONFIGURE
byte mac = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
IPAddress ip(192, 192, 192,129); // ip address
EthernetServer server = EthernetServer(80); //port 80
char servername = “http://*************.no-ip.org”;
void setup(){
//Pins 10,11,12 & 13 are used by the ethernet shield
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
Ethernet.begin(mac, ip);
server.begin();
Serial.println(Ethernet.localIP());
long time = 0;
long debounce = 200;
void loop(){
// process request.
checkForClient();
void checkForClient(){
if (client) {
boolean currentLineIsBlank = true;
boolean sentHeader = false;
while (client.connected()) {
if (client.available()) {
if(!sentHeader){
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connection: close”);
client.println();
client.println("");
client.println("");
client.println("");
client.println(“Arduino Control”);
client.println("");
client.println("");
client.println(“
ARDUINO UNO PROJECT
client.println(“
Home Automation Ver 1.0
client.println(“
This program operates pin 2-9 on the adruino via the ethernet shield conformation of operation by Pin.
client.println();
sentHeader = true;
char c = client.read();
if(reading && c == ’ ') reading = false;
if(c == ‘?’) reading = true; //found the ?, begin reading the info
if(reading){
Serial.print(c);
switch (c) {
case ‘2’:
//add code here to trigger on 2
triggerPin(2, client);
client.println(“
Garage Door
case ‘3’:
//add code here to trigger on 3
triggerPin(3, client);
client.println(“
Garage Lights
case ‘4’:
//add code here to trigger on 4
triggerPin(4, client);
client.println(“
Intruder Alarm
case ‘5’:
//add code here to trigger on 5
triggerPin(5, client);
client.println(“
Access Control
case ‘6’:
//add code here to trigger on 6
triggerPin(6, client);
client.println(“
Garage Heater
case ‘7’:
//add code here to trigger on 7
triggerPin(7, client);
client.println(“
NOT USED
case ‘8’:
//add code here to trigger on 8
triggerPin(8, client);
client.println(“
NOT USED
case ‘9’:
//add code here to trigger on 9
triggerPin(9, client);
client.println(“
NOT USED
if (c == ‘\n’ && currentLineIsBlank) break;
if (c == ‘\n’) {
}else if (c != ‘\r’) {
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(2);
// close the connection
client.stop(); // close the connection:
void triggerPin(int pin, EthernetClient client){
client.print("Turning on pin “);
client.println(pin);
client.print(”
digitalWrite(pin, HIGH);
delay(400);
digitalWrite(pin, LOW);
delay(400);
long time = 0;
long debounce = 1000;
Edit your post and insert code tags!
Here's the immediate issue:
delay(400);
That second digital write is the problem. Naiively, you could just remove it but then you would need to add a different message to close it. Or you could keep a global boolean for each thing you're controlling to indicate whether its high or low and toggle it whenever you receive instruction to change it.
the outputs don't latch when triggered i only get a momentry pulse
Not surprising:
  client.print("Turning on pin ");
  client.print("
  delay(400);
  delay(400);
long time = 0;
The time and debounce variables are doing nothing, since they go out of scope immediately.
I'm guessing that you see a 400 millisecond pulse, right?
So, write the code that way.
