Web Edit
Arduino R4 Wifi, MacOS 13.4.1, MacMini M1
Using Safari, I'm unable to connect with my Arduino board. I have installed the create agent and tested it using Chrome and it works fine. However, on Safari I see this:
Also, no port menu on this screen:
Using Chrome, the Web Editor, everything fine:
Also works fine with IDE.
Hi!
Could you please try the following?
Verify that the Create Agent is running
Open the Create Agent menu (you should have the Create Agent on the status bar).
Click on "Generate and Install HTTPS certificates".
Try again to ADD the device
Let me know if this helps!
Thank you. This solved the problem.
system
Closed
February 4, 2024, 12:16pm
4
